Gas tank replacement? Really?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dragon129, Feb 3, 2016.
  1. Feb 5, 2016 at 10:48 AM
    #41
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
  2. Feb 5, 2016 at 2:37 PM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Looking at that nipple for the fuel tank vent hose, I'm sure that can be repaired with epoxy and/or an adapter.
  3. Feb 5, 2016 at 3:05 PM
    #43
    Ten Rounder
    Ten Rounder Old Man and his Dog
    Southwest Montana
    20 TRD Offroad, 19 4Runner Premium SR5
    Heated seats, It's Montana
    Are these tanks metal, plastic, or a composite?
  4. Feb 5, 2016 at 4:20 PM
    #44
    Jimmyh
    SC
    2012 Prerunner SR5
    Layered Composite.
  5. Feb 5, 2016 at 4:21 PM
    #45
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Comp or plastic.... not metal though.
    A couple of years ago, a member changed his tank for some reason. He cut it open and was very surprised at how clean it was inside.
  6. Feb 5, 2016 at 4:24 PM
    #46
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My wife's 09 Honda had the check engine light come on 4 years ago. Got the same diagnosis. They replaced the entire fuel system and tank under warranty. I didn't ask why since I wasn't paying for it. But figured they wouldn't have done it for free if it didn't need being done.
  7. Feb 5, 2016 at 5:16 PM
    #47
    dragon129
    dragon129 [OP] Mod wannabee
    Lexington Park, MD
    05 speedway blue PreRunner Double cab
    No mods
    That doesn't look bad to change. Looking at that though, it doesn't show anything on the male side of that connector being a separate piece. I guess that's why they want to change the tank. I'll find out soon enough. Just not exactly sure when. I am moving out of my house today and taking the family to Maryland. Gotta clean house tomorrow.
  8. Feb 5, 2016 at 5:52 PM
    #48
    Dusty1
    Dusty1 Member
    Greg
    So Cal
    2014 4X4 Access Cab
    Shell, Storage Boxes
    So I had this happen to me (with another vehicle, Jeep) (Yea, I got rid of it and got a Tacoma) The tanks are Composite / plastic, and some of the tubing connections are molded in. Break a connection and you scrap the whole tank. I am surprised there isn't an aftermarket kit for this kind of fix. Make sure they don't have to replace it for free. (part of the smog system) Dropping a tank isn't too bad, make sure you have disconnected everything so you don't snap another connection. If well de-greased, epoxy should do the trick. Sometimes I mix in a piece of cloth to improve the flex strength of the patch. Good Luck!
    You might find an equivalent model year that has been in a front end accident and totaled. The tank might still be good.
  9. Feb 6, 2016 at 5:28 AM
    #49
    UltraE05
    UltraE05 Well-Known Member
    2010 Tacoma Crew Cab
  10. Feb 22, 2016 at 5:30 PM
    #50
    dragon129
    Lexington Park, MD
    No mods
    Update, sort of....I dropped the tank and replaced the line recommended by the Toyota technician. Reset the light and don't have enough miles yet for it to come on again. Nothing looked out of the ordinary but I am not an EVAP tester so that leak probably still exists. I'm thinking if this does not work, the next step will be 3M 5200 around the fittings of the tank around the vapor line and the fuel fill line to eliminate that leakage. I don't think it's the fuel gasket around the fuel pump but I might do that one too. Till this weekend.
  11. Mar 7, 2016 at 4:14 PM
    #51
    dragon129
    Lexington Park, MD
    No mods
    And the winner is......Blacktaco2042. My guess is a squirrel. I have a lot of them around my house. There are two distinct chew holes about an inch apart. There is plenty of room on top of the tank for a little rodent to sit and there's nothing around the hose to cause chaffing. I just cut the line and spliced a fuel line in and clamped each end. Tada.....No more check engine light. How I missed the holes the first tank drop is beyond me. It was clearly obvious when I dropped it the 2nd time.
  12. Mar 7, 2016 at 4:20 PM
    #52
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    Yea I have seen it a few times. It happens. At least you fixed it cheap and doesn't need a tank. Only time I had to replace a tank is cause a place drilled thru the tank mounting a in bed Salter unit
