Gasoline odor
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbbb, Oct 24, 2010.
  1. Oct 24, 2010 at 1:48 PM
    jbbb
    jbbb [OP] New Member
    Ma
    2001 4x4 double cab short bed
    I have 140 K on my 2001 double cab. Over the past couple months I notice a gasoline odor after I park, turn off the engine and I step out of the truck (only outside cab, not inside). It occurs during the 1st quarter tank of gas after a fill up. I mainly notice the odor coming from the gap between the rear of the cab and the bed. Could there be some kind of vent valve or hose that is malfunctioning or has become disconnected? any help would be greatly appriciated.
  2. Oct 24, 2010 at 2:03 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    probably the fill tube. check that 1st. do you have a body lift? my 99 taco had one and the extension i put on the fill neck leaked a little
  3. Jul 4, 2011 at 2:45 PM
    TacomanTRD
    TacomanTRD New Member
    02BLK4DRTRD
    Researching 3" Suspension Lift
    i'm having the same problem. did you figure out what it was?
  4. Jul 4, 2011 at 6:51 PM
    JAJI4
    JAJI4 Well-Known Member
    Sunshine State
    2001 Tacoma; Double Cab; TRD Offroad; 2WD
    Mine had a similar odor right after I bought it several months ago. (I have a 2001 prerunner) A friend down the street mentioned it might be the charcoal canister (?) but recommended that when I fuel up, let the pump shut itself off and do not top off. I followed his recommendation and it hasn't smelled of gasoline since.
  5. Jul 5, 2011 at 5:53 AM
    TacoMan709
    TacoMan709 Well-Known Member
    Newfoundland (the Rock)
    03 Tacoma Xtra cab 4x4
    285 km2s, 2.5" lift, mashed pinch weld, Flowmaster, wicked piss
    Put your ear to the cab-bed juncture and listen...gremlins.
