Gauge Cluster Protector
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, May 9, 2025.
  1. May 9, 2025 at 3:40 PM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
    I have a 2017 SR5. I am looking for a protective film to put over my gauge cluster on the dash to mitigate scratches. I see the screen pro tech brand options but they seen to only sell packages that include other things I don't need. Act advice?
  2. May 9, 2025 at 3:44 PM
    soggyBottom
    soggyBottom Well-Known Member
    Clear tint would work perfectly. Removing could be difficult
  3. May 9, 2025 at 3:57 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    soggyBottom likes this.
  4. May 9, 2025 at 6:58 PM
    yoeltimeisup
    yoeltimeisup Member
    Just got a used DCSB OR and the cluster has a lot of scratches of course. I plan on replacing the plexiglass and putting on a Screen Protech kit. The headunit and climate control film with help protect them from finger smudges and scratches.
    t0p_d0g likes this.
  5. May 9, 2025 at 6:59 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Just buy the kit, it’s worth it from SPT.
    musicisevil likes this.
  6. May 9, 2025 at 7:32 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    If anyone decides to replace the plexiglass lens they’re three different part numbers for different trim levels so make sure you order by VIN no.
    Chew, musicisevil and yoeltimeisup like this.
  7. May 10, 2025 at 2:55 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I had some light scratches from using a microfiber towel and did buy a new cover from Toyota but I was ale to polish itand use a Ceramic coating and its crystal clear now.
  8. May 10, 2025 at 4:10 AM
    soggyBottom
    This is the most logical solution.
    83852-04F00 currently about $32. The screen protec kit is $65. I don't see the point in putting a plastic cover that costs more than the thing you're protecting.
    TA2016[QUOTED] likes this.
  9. May 10, 2025 at 4:37 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    yoeltimeisup likes this.
