Gauge trim/hood removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by STLTaco09, Jun 22, 2009.
  1. Jun 22, 2009 at 7:30 PM
    STLTaco09
    STLTaco09 [OP] Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Anyone know how to remove the grey trim piece that goes around the gauge cluster and the far left most A/C vent? It's the piece that is shaped like a hood over the gauge cluster.
    I know you're supposed to remove the two screws pointing upward on the "hood" part of this piece. Then what?
    Seems like these two screws just keep spinning for me. They don't seem to tighten or loosen at all. Any ideas?
  2. Jun 22, 2009 at 7:56 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    They are not really threads. You need to use very light pressure and back them out, enough so you can get your finger nail in there. Then work it out the rest of the way.
    That whole piece comes out together. But the entire bottom section of the dash must be removed first.
    Good Luck!
  3. Jun 23, 2009 at 3:25 AM
    STLTaco09
    Cool, thats a little reassuring. This is my issue, The piece where the gauge trim/hood right above the A/C vent on the left by the dimmer knob bumps up to the actual flat dashboard piece above the gauge cluster has a gap in it. I can almost see in between each piece. Are there clips that hold this joint together? Or does something else just need to be tightened? Its such a stupid little thing, but it is driving me completely crazy!
