Gauging interest: 1" ball mount phone holder
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Revelations, Jul 8, 2024.
  1. Jul 8, 2024 at 12:46 PM
    Revelations
    Revelations [OP] Well-Known Member
    2014 MGM DCSB
    I'm looking to see if anyone would be interested in a ball mount sized to fit in the grab handle. This is similar to the ram mount idea. This is 3d printed from PETG and uses a 75mm hex bolt. Single piece construction eliminates any guess work trying to use extra nuts and washers to space the Ram mount. I used a 1" to .75" ball adapter to make it work with my wireless charger pad.
    Kit would include the ball mount, 1x 75mm (or 80mm depending on availability) hex bolt, 1x M6 flat washer, 1x M6 lock washer.
    Swivel arm not included.
    The color is a great match to the oem gray interior. I can also do black, red, and yellow.
    Price would be $15 shipped in the US.
    mkhawks44 and GilbertOz like this.
  2. Jul 8, 2024 at 1:04 PM
    slossboss
    slossboss Well-Known Member
    Troy
    FL
    2013 TRD Sport 4x4 Nautical Blue Metallic
    Great idea. Seriously I think this is very clever and a wise purchase for whoever is curious about this mod.
    i definitely have some trial and error to do with the washers and nuts that are currently spacing my ball mount. The mount itself maybe does not have enough thread as it loosens gradually. Just annoying enough to keep living with.
    Question: what size ball is this, or what is it equivalent to? Please correct me if I’m wrong but the A pillar ram mount thread is based off of the ‘size B’ ram ball. Does this matter when considering Ram or other accessories. I think that’s an important consideration for any potential buyer.
    Revelations[OP] likes this.
  3. Jul 8, 2024 at 1:22 PM
    Revelations
    2014 MGM DCSB
    I believe it is size B for ram mount. As a matter of fact, I started with a ram mount (RAM Mounts RAM-B-367U Motorcycle Handlebar Clamp Base with M8 Bolts with B Size 1" Ball https://www.amazon.com/dp/B005J43I56) but experienced the same loosening that you had. Although, I started with a 3d printed spacer instead of the various nuts people used for spacers.
    Initially, I thought it was an issue with the TPU material that's used. You can see it get deformed when the interior gets hot. I tried an all aluminum ball mount, but it also just became loose. Having the mount just swing back and forth irritated me. That's why I decided to make a 1 piece that you bolt in and is compressed with the bolt and lock washer.
    The ball mount is a 1" ball like the ram mount.
  4. Jul 8, 2024 at 5:14 PM
    Revelations
    2014 MGM DCSB
    Finished product
    TacoTimeTuesday and mkhawks44 like this.
  5. Jul 8, 2024 at 6:49 PM
    illjimae
    illjimae Well-Known Member
    Only concern is, handlebar is load bearing, I would suggest using ASA if you can. In addition it has a higher glass transition versus PETG.
    GilbertOz likes this.
  6. Jul 8, 2024 at 7:48 PM
    Revelations
    2014 MGM DCSB
    PETG is nearly as strong as abs and the walls are solid with 30% sparse infill. I've been using it already and haven't had issues. My 3 piece swivel mount is at least 2 lbs because it's solid steel. If I was afraid it would break, I wouldn't use it or sell it.
  7. Jul 8, 2024 at 7:56 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Might be nice if it could eliminate most of that tinker toy Rube Goldberg setup.
  8. Jul 8, 2024 at 8:40 PM
    Revelations
    2014 MGM DCSB
    Sorry. Not sure what you mean?
  9. Jul 8, 2024 at 8:46 PM
    illjimae
    Believe he meant all those arms between the ball and phone mount
  10. Jul 8, 2024 at 8:51 PM
    soggyBottom
    soggyBottom Well-Known Member
    I was going to joke about using a uniball but the more I think about it, the more I think it's a good idea. They won't wear out like the plastic ones. A 1/2" one from heimjoint.net is $12
  11. Jul 8, 2024 at 8:57 PM
    Revelations
    2014 MGM DCSB
    That's just my own set up. Everyone has their own preferences, so that's why I'm not trying to include any arms. There are plenty of alternatives.
    HondaGM likes this.
  12. Jul 8, 2024 at 9:00 PM
    Revelations
    2014 MGM DCSB
  13. Jul 11, 2024 at 10:00 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    This, a selling point would be if you could eliminate all that stuff even if (or especially) only for your own mount. If YOU can’t get by without it, how is anyone else supposed to? Maybe it’s a “look” and I’m just old. Just my impression but to me it’s the start of a good idea that isn’t complete.
  14. Jul 11, 2024 at 10:10 AM
    Revelations
    2014 MGM DCSB
    Until you actually have one, you won't understand. The adjustable arms are necessary because phones have different dimensions. If I designed a 1 piece to only fit my phone, I would be limited to sell to people with the same size. Some people have larger phones so the arm lengths would need to be adjusted. There are multiple factors when mounting a phone in that area. Even the wireless charger I have makes it unique because when it automatically closes, the bottom moves my phone up about .5". So if someone else's doesn't do that, the phone position may be too low for them. There are far too many factors to suggest a 1 size fits all solution. Thanks for your input.
    HondaGM likes this.
  15. Jul 11, 2024 at 12:44 PM
    mkhawks44
    mkhawks44 Well-Known Member
    Oregon / Kansas
    2014 Barcelona Red Reg Cab
    I'd buy one. Would work great with my quad lock setup.
  16. Jul 11, 2024 at 1:04 PM
    Revelations
    2014 MGM DCSB
    Pm me when you're ready to buy one. Thanks!
    mkhawks44[QUOTED] likes this.
  17. Jul 12, 2024 at 9:59 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    You’re right of course. Your targeting those who already have the tinker toy setup while I’m part of the “less is more” crowd. I can’t even see my phone mount with the phone in place. FWIW I like what you are making, it’s the pieces between it and the phone that I find excessive.
