Gear box drain and fill
Discussion in '1st Gen. Tacomas (1995-2004)' started by twfsa, Oct 20, 2010.
  1. Oct 20, 2010 at 4:15 PM
    twfsa
    twfsa [OP] Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Changed the diffs and transfer case today used what the owners manual said for weights, as clean and clear as the fluid was I drained out, it made me wonder why I was changeing it, 52 k on my truck and I would say if you haven't been in deep water don't mess with it. Going to the dealer for a trans flush.
  2. Oct 20, 2010 at 4:19 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I here you there. I changed my rear diff fluid and it looked brand new I didn't know when the previous owner did it last so I did it any way. I'm going to be changing the transfer case tranny and front diff soon just so I know what's in there and when it was done.
  3. Oct 20, 2010 at 4:32 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    how much fluid does the transfer case take, im putting a new one in, the manual said 1qt for a complete refill but i got 3 to err with the side of caution
  4. Oct 20, 2010 at 4:54 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    the tcase takes 1qt anymore and it starts comin out the fill plug
  5. Oct 20, 2010 at 4:58 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    thanks, ill use the rest in my front diff lol
  6. Oct 20, 2010 at 7:17 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    tcase and manual trans the fluid will look good and maybe your front diff but rear diff will come out looking dirty. i rec changing all drive line fluid every 15k.
  7. Oct 20, 2010 at 7:29 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    im only changing the t-case and trans because im replacing both lol, im replacing the front diff fluid because im putting on a beefier differential cover :p, i did it all about 10k ago so im prolly good another 20k or until i totally abuse it or dunk it underwater
  8. Oct 21, 2010 at 8:44 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    15 K change out waste of money and time, unless you think you have water in it, and at that it should be changed imediately!Save your money for beer!
