Gear Head's 82 Pickup Build
Discussion in 'Other Builds' started by Gear Head, Apr 25, 2014.
  1. May 7, 2014 at 8:16 AM
    #81
    ttaM
    ttaM 4.8.15.16.23.42
    Kentucky
    2002 Tacoma 2.4L 5 Lugger
  2. May 7, 2014 at 12:57 PM
    #82
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Oh my. I love where this is going.
  3. May 7, 2014 at 6:06 PM
    #83
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    Sweet trucks man! Both of them are awesome :thumbsup:
  4. May 8, 2014 at 3:21 AM
    #84
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    One word. BADASSNESS!! Well done.
  5. May 8, 2014 at 5:59 AM
    #85
    Gear Head
    Gear Head [OP] Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    I really appreciate the compliments guys! I think the tan turned out freaking awesome. Love it so much I'm not going to to bedline the rockers anytime soon. I'm getting my 220 plug wired Monday so hopefully I can get some practice time in with the new welder and if I can find a local metal supplier I will be building a set of sliders very soon. I've also been talking with a member about him coming over and putting his lift on for him so I can get his stock suspension for the Tacoma and then I'll be able to swap the 63's and bilsteins over to the pickup!
  6. May 8, 2014 at 10:04 AM
    #86
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    So I was out running errands in the pickup today and found a pavement bank/loading dock to mess around on. Went over it in 2 low first gear and even with the 4.7's it still felt pretty fast and didn't have much control. There's going to be a big learning curve for wheeling a manual but 5.29's just moved up the priority list.
  7. May 8, 2014 at 3:39 PM
    #87
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    If you use the brake to keep it under control and the gas just to keep it alive it should be slow enough for your liking. Brake throttle modulation take some getting used to but it helps keeping everything under control and steady.
  8. May 11, 2014 at 1:40 PM
    #88
    T4rwildlife
    T4rwildlife Well-Known Member
    Alek
    Haywood/Alexander
    2000 4runner
    Ome 3in lift
    Looks awesome man, can't wait to see this thing!
  9. May 11, 2014 at 4:58 PM
    #89
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Thanks bud! That'd be a long ass drive in this thing haha. It aint no Cadillac...
    So I found some 5.29's with welded carriers for $300 and I'm wondering if it would be worth my time. The reason I ask is because yes I could run them welded but, I'd rather run lockers since I run this thing on the street and plan on driving it to the trail for a while. So basically I'm paying $300 for used gears and would still eventually have to pick up two install kits and a locker and an open carrier for when I don't want to run welded anymore. Or should I suck it up and run them welded because I plan on selling the tacoma and picking up a full size 4 door later this year or sometime next that I'll be able to tow it with.
    And just for comparison I found one 5.29 r&p new in box for $100 and the other r&p and 2 install kits from ECGS is $465.
    Annnnd one more thing, what could I get out of my diffs if I decide to sell? 4.10's, one is welded, one has a lock right and triple drilled flange.
  10. May 12, 2014 at 5:19 PM
    #90
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Got my 220 plug wired today but I was up from 9am Sunday to 10am Monday so I haven't even messed with it, I just went to sleep haha. Probably working a lot overtime this week so I probably wont be able to get it dialed in till the weekend. Hoping to pick up some material for sliders soon and once I can get my last stock piece for the Taco I can swap the 63's over then bob and dovetail :D
  11. May 13, 2014 at 5:04 PM
    #91
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Practicing for the truck. First and last weld after about 30 min of messing around with gas flow and pulling out fucking birds nests
  12. May 13, 2014 at 5:56 PM
    #92
    Redneck92
    Concord, NC
    What kind of gun technique are you using?
  13. May 14, 2014 at 9:57 PM
    #93
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Probably not a good one lol. I hold it at 45* to the joint, I pull my welds, and run about 1/2" stick out. I was referred to weldingtipsandtricks.com so I've been watching videos on there and going to try some different things when I pick up som new wire.
  14. May 15, 2014 at 6:40 PM
    #94
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Here's a pic with of one the welded 5.29 thirds..
  15. May 15, 2014 at 6:56 PM
    #95
    Redneck92
    Concord, NC
    Yeah that's not the good way to weld them. Welding them to the carrier like that will weaken the carrier. Usually you would cut a rectangle plate out that would fit between the 4 spiders and the plat to the spiders and do that for opposite side as well.
  16. May 15, 2014 at 10:30 PM
    #96
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    So I guess the question is, is it worth $300? I came across a guy with a brand new ring and pinion for $100 and the other ring and pinion and 2 install kits are $465 from ECGS so $565 then I still have to set them up which I have never done.
  17. May 17, 2014 at 4:47 AM
    #97
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Problem solved
    And I've been talking to a guy who wants to trade his 37x12.50x16.5 with wheels for my 35's and wheels. He's supposed to get back to me today
  18. May 17, 2014 at 7:29 PM
    #98
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Took the '82 to a Triad 4x4 meet and greet tonight. Some pretty sweet rigs there
    Badass pickup
    Custom diesel 4 door yj on 53's
    My gf is 5'3" for reference..
  19. May 18, 2014 at 5:57 PM
    #99
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Got the 82 on some logging roads behind my parents' today. Welded rear is pretty sweet in the dirt! Never put it in 4x4 in places that my tacoma needed it. 4.7 tcase gears are amazing too! Went to pull up a bank for a 3 point turn and since I wasn't in 4x4 the front tires wouldn't climb so just for shits and giggles I just let the clutch out with no gas and the rears just spun real slow and the truck was pinned on the bank haha.
  20. May 18, 2014 at 7:17 PM
    #100
    taco terror
    taco terror 1st gen = best gen
    North Carolina
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
