Gear oil for rearend?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RaiderSix, May 18, 2007.
  1. May 18, 2007 at 8:07 AM
    RaiderSix
    RaiderSix [OP] Well-Known Member
    The manual for my 97 2WD says that the rearend uses straight 90 weight SAE Hypoid gear oil. I can't find straight 90 weight in the stores. Is there any other weight suitable for use in the rearend?
  2. May 18, 2007 at 10:30 AM
    sgtlarkin
    sgtlarkin New Member
  3. May 18, 2007 at 11:14 AM
    RaiderSix
    Thanks. Good to know I'm not the only one. :D
  4. May 18, 2007 at 2:20 PM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
  5. May 18, 2007 at 5:28 PM
    RaiderSix
    Well, I bought some 80W-90 Valvoline and did the rearend and tranny today after work. Very simple job. I was surprised at how thin the gear oil was. I feel better now that I've changed it. Next is a radiator flush and some new antifreeze to replace the brown stuff in there now. :D
  6. Jul 6, 2009 at 9:31 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Should use the dealer antifreeze--store bought stuff doesn't mix well with the Toyota Long Life coolant.
  7. Jul 7, 2009 at 4:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  8. Jul 7, 2009 at 8:11 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    It will if you use the new Clear Prestone.! I bought the Dealer crap! 28$ a gallon!
  9. Jul 7, 2009 at 8:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    Brown?
    You mixed the yota pink with the green stuff I take it?
  10. Jul 7, 2009 at 12:03 PM
    PrezidentRedz
    Redz
    Owings, MD
    Brown, that means rust! and dirt~!
  11. Jul 7, 2009 at 8:26 PM
    saltbranch
    saltbranch Well-Known Member
    Tx
    1996 2.4,2wd,5spd, stock, 250k
    I am going to preface this with by saying I am a Lucas oil fan. On the rear diffs of my hotshot trucks I used a 50-50 combo of gear oil and Lucas Oil Stabilizer.. workes good for me.
    Speaking of radiator flushes has anyone heard of using Cascade(like for the dish washer) as a flush? My day job, I have 8 trucks from 3/4 ton to big rigs plus 7 forklifts I am in charge of. I am currently having the forklifts -all fluids changed --bi annual PM service. The mechanic service is doing this on site for the first time and they are using Cascade for the flush, having us run the units 1 day after adding Cascade. Then flushing system.
    In the past, we always had the forlifts taken to the mechanics shop via tow trucks for bi annual service, got a rental forklift for the PM service time. Times are tight so they are doing it on site.
    I have never heard of this..has anyone else? The Mech. doing the Pm is telling me use 1/2 a box for my taco to flush. This same shop has been our go to mechanic shop for over 10 yrs, I talked to the owner today and he swears by cascade for radiator flushes...just blew me away..never would have thought of that.
  12. Jul 8, 2009 at 10:09 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Sounds bad to me. Use a 50/50mix of water and white vinegar to flush. then re-flush with water. Then Refill with new coolant.
  13. Jul 8, 2009 at 10:19 AM
    98tacoma27
    Ben
    Not Beech Creek
    When you mix yota pink fluid with green anti-freeze it turns brown and yucky.
  14. Oct 29, 2009 at 9:44 PM
    PAPAOBEWON
    PAPAOBEWON Member
    COLORADO
    2002 Tacoma TRD DC 4X4 S/C
    3" FABTECH LIFT, WARN WINCH, ARB FRT BUMPER, SHELL, S/C
    Vinegar should never be used, it is acidic!!! and; that is basically what antifreeze breaks down into if you have used this technique I would be running a mix of baking soda and water (arm and hammer) to neutralize the acid, Acid will eat aluminium!:eek:
    My father-in-law uses white vinegar to strip the coating off of his NEW rain gutters before painting them (this lets you know how caustic vinegar can be)
  15. Oct 29, 2009 at 10:05 PM
    PAPAOBEWON
    PAPAOBEWON Member
    COLORADO
    I have read all the different opinions about what is the best synthetic to use.
    Everyone has a personal preference. Today I called over 20 Transmissions shops to find out what they use. It ranged from Amalie, Merc V, to Valvoline. I found this White Paper on 14 lubes and decided this was as close as I was going to get to an objective analysis. Yes it was conducted by Amsoil and No I am not affiliated in any way with their firm. I am just an 'old school' - back yard mechanic that wants proof. So I figured if they published it and they were not Sued by any of the companies they mention in the report there must be some validity. For what its worth I share my findings. Today is Oct. 29, 2009 the report was from 2007. I have been looking for 2 days to find any objective information --- here is the link if you wish to peruse for yourself. I am a new member and hope this is OK to report.
    Happy Birthday Karen I love you!:D
    http://www.amsoil.com/lit/g2457.pdf
  16. Oct 30, 2009 at 5:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    Very interesting read.
  17. Oct 30, 2009 at 2:40 PM
    PAPAOBEWON
    PAPAOBEWON Member
    COLORADO
    It is interesting that different lubes had superior properties in certain tests. I was ready to buy Redline(especially when "Red" showed us his rear end pictures").
    When I called the Transmission Shops most of them use
    Valvoline MaxLife yada yada, I was about to go with this brand when I discovered that it has additives that supposedly works on regenerating the SEALS I have read on many forums that this is a big mistake!
    Q. Does anyone have any experiences with brands of gear lube that refresh the seals and have done damage?
    Q2. I have an Electronic Locker in the rear end, I believe this rear end DOES NOT NEED (LSD) LIMITED SLIP DIFFERENTIAL ADDITIVES, is this a correct assumption.
    I hope to hear from many of you, I just bought a bunch of parts to put on my tacoma, arb bull bumper and headlight grill guard, warn 8000# winch, supercharger, timing belt, water pump, tensioners, etc,.
    I read some of the threads and found the website with all the mods and pixs that was cool. I ramble on so I better stop!
    Mark the backyard Mechanic:p
  18. Oct 30, 2009 at 10:17 PM
    Janster
    Jandy
    Lancaster, PA
    Yes...absolutely.
    If you have the TRD E-locker, you do not need the LSD additive. Look at your owners manual to get the proper oil required.
  19. Oct 31, 2009 at 10:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2
    I used Amsoil in my 98.
