Gear oil question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, May 11, 2015.
  1. Jul 30, 2016 at 9:16 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Eaton approves both conventional and synthetics from the major lubricant suppliers for use in their drivetrain components, so it would seem that it doesn't matter that much.
    http://web.eaton.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/pct_223059.pdf
    I tend to be kind of obsessive about checking fluids, touching wheels and drivetrains when I stop for gas or rest areas. I once pre-empted a wheel bearing failure because I noticed one hub was a lot warmer than the other, for example. The only personal observation I can add is that my gear sticks (especially the transfer case, that was a huge reduction) and rear axle housing were "noticeably" (which I admit is a subjective determination) cooler to the touch after switching to synthetic in my old truck. I switched the new truck over to synthetic during my baselining right after buying it, so I don't have a frame of reference to know if it would be true in it, though.
  2. Jul 31, 2016 at 6:41 AM
    1997tacomav6
    Denver
    I have been running Amsoil it's whole life in 5 speed trans, diff, transfer, and now at 500,000 miles
    all original parts with no issues and supercharged.
    JPinFL likes this.
  3. Jul 31, 2016 at 6:59 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    It's perfectly fine, I ran Mobil LS in my 03 cases for 80k and I have It in my 15' cases now. Synthetic should just be avoided in the rear end if you have a mechanical LSD. 09' and up do not have those.
