Gear Oil Weight and Spec
Discussion in '1st Gen. Tacomas (1995-2004)' started by montanabay, Jun 28, 2010.
  1. Jun 28, 2010 at 9:10 AM
    montanabay
    montanabay [OP] Active Member
    CA
    2.7L 4WD AUTO
    Hi All,
    First Question, I've come across a few different sources that GL-5 gear oil can be corrosive in certain gear boxes, particularity Japanese made transfer cases because of the high sulfur content and specific metals in there transfer cases.
    My manual for my 1996 Taco says GL-4 for the transfer case and GL-4 or 5 for the differentials. My question is, can we put GL-5 in our transfer case or is it one of these sensitive metal cases?
    I ask because no one carries GL-4 spec oil around here, everything is GL-5, so I wonder if GL-5 has evolved to be safer with specific metals?
    Second question, my rear diff is rated for 75w-90 oil, if I put in 90w-140 would it have any negative impact on the diff, or just more protection with more resistance (less mpg)? I tow with my truck, so I want to make sure she' as protected as possible.
    Thanks!
    Josh
  2. Jun 28, 2010 at 9:15 AM
    98tacoma27
    Ben
    Not Beech Creek
    You can put a synthetic GL-4/5 in the transfer/tranny with out issue. Dyno GL-5 will SLOWLY eat any copper alloy which happens to be the bronze synchros in the W58/59 tranny.
    Stick with the recommended 75w-90 in the diffs, or go synthetic.
  3. Jun 28, 2010 at 9:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Toyota does say a GL-5 is fine in their tranny though.
  4. Jun 28, 2010 at 10:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I had a 96 tacoma and I put Mobile 1 75W-90 gear oil in everything!!!
    Front diff, rear diff, transfer case, & manual transmission.
    And since you tow...use the recommended oil and just change it more often.
    Using a 90-140w oil could cause more problems because the oil is too thick. Too thick = not flowing properly to lubricate the diff & wheel bearings properly.
  5. Jun 28, 2010 at 8:35 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    I just replaced my diff oil with Royal Purple 75W90.
  6. Jun 28, 2010 at 8:39 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    GL4 in the trans and case, GL5 in the diffs.
    check out www.racerpartswholesale.com its the best price for what i plan on putting in my truck whenever i get around to it (Redline 75w-90 in diffs , MT-90 in trans and case)
  7. Feb 2, 2012 at 7:53 AM
    bluebr65
    bluebr65 Active Member
    Bear
    Pittsburgh, PA
    01' SR5 4x4 5Spd
    Does this still hold true? I just put GL5 Mobil 1 75w90 synthetic in my tcase and manual trans (2001 2.7). Have I made a huge mistake??
  8. Feb 2, 2012 at 8:51 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Is this a trick question? He said "put a SYNTHETIC GL-4/5 in the transfer/tranny with out issue... DYNO GL-5 will slowly eat..." You said "I just put GL5 Mobil 1 75w90 SYNTHETIC in..."
    Translation: You're using SYNTHETIC, so you're fine.
  9. Feb 2, 2012 at 9:12 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    Redline MT fluid specifically states it is compatible with both GL4 and GL5
