Gear Oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ICECOLDBEER, Aug 21, 2022.
  1. Aug 21, 2022 at 1:27 PM
    ICECOLDBEER
    ICECOLDBEER [OP] Well-Known Member
    2006 Tacoma 2.7L SR5
    Does the viscosity matter for rear diff oil? My manual states:
    Front Diff: SAE 75w-90
    Rear: Above 0 degrees F- SAE 90
    Below: 0 degrees F- 80w-90 or SAE 80W.
    All I can find locally is 75w-90 and 80w-90.
    Thoughts? We get below 0F a couple times a year.
  2. Aug 21, 2022 at 1:46 PM
    ICECOLDBEER
    Actually all I can see locally is the 80w-90.
  3. Aug 21, 2022 at 1:49 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    tacoman45, NAAC3TACO and Chris(NJ) like this.
  4. Aug 21, 2022 at 1:52 PM
    ICECOLDBEER
  5. Aug 21, 2022 at 2:06 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  6. Aug 21, 2022 at 2:07 PM
    Key-Rei
    Key
    Florida
    Royal Purple is pretty decent, IIRC the rear calls for closer to 3 or 4 quarts but I never go by volume, keep putting it in the fill plug hole till it just barely starts to dribble out, that's the "full" line.
    Chuy likes this.
  7. Aug 21, 2022 at 2:17 PM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    Key-Rei likes this.
  8. Aug 21, 2022 at 3:41 PM
    ICECOLDBEER
  9. Aug 21, 2022 at 3:43 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  10. Aug 21, 2022 at 3:44 PM
    ICECOLDBEER
  11. Aug 21, 2022 at 7:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    75w-90 or 80w90 will be fine.
    They are both a 90 weight oil.
    The only difference is how they flow cold.
    And the differential won’t stay cold long enough for 5w point to matter.
    I used 85w-140 in my front differential.
    If I were to do it over, I would have just used 75w-90.
    I’m using 80w-90 in my rear differential.
    We don’t get below 0. About the lowest we see is low teens.
    We might see single digit or near 0 once every 50 years.
    tacoman45 and Key-Rei like this.
  12. Aug 21, 2022 at 10:23 PM
    leid
    Brandon, MS
    Yes, the 80W-90 is a HD dino oil. And it probably has a very similar additive package to the 85W-140 HD Lucas dino oil that ECGS thinks so highly of. Given your climate, the 80W-90 HD Lucas dino oil would be a very good choice IMO. The 85W-140 HD Lucas dino oil is what I will be picking up tomorrow for use down here in MS. I have used both Amsoil and Red Line synthetics. Both were very good gear oils.
  13. Aug 21, 2022 at 10:29 PM
    TnShooter
    Deogee
    STOCK
    Here is my experience with the heavier oil.
    I’m not the only one to have this happen.
    If it gets below 50 degrees where you live, I’d maybe stick to 90 weight.
    https://www.tacomaworld.com/threads/front-diff-leaking-gear-oil-from-the-breather.744067/
  14. Aug 22, 2022 at 1:52 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I have some Lucas 85-140 fs….if it’s what you’re looking for and it’ll save you a few bux…. (Although not sure w shipping)
    https://www.tacomaworld.com/threads/fluids-randoms.761843/
  15. Aug 22, 2022 at 5:56 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
  16. Aug 30, 2022 at 1:20 PM
    MVMike
    MVMike Well-Known Member
    2016 White Tacoma TRD OffRoad Double Cab
    Just changed my 2016 rear diff oil at 95K mi. It was still clear and gold. Unlike any other disgusting stinky black gear oil Ive ever changed. Manual says GL-5 Synthetic. I went back with Mobil1 80-90W Syn. Super easy change. 4qts didn’t fill to the fill threads but I measured what came out and it was only 4qts.
  17. Aug 30, 2022 at 1:35 PM
    saint277
    saint277 Vigilo Confido
    Bit of an odd article. Says lucas dino is better than synthetic oil, than says serval synthetic oils perform as good as or better than dino lucas. Interesting statement about heat and diff OCI, I had always thought that the increased resistance to flow, from a thicker oil, would increase the heat of the fluid. Guess I would need to see some data.
  18. Aug 30, 2022 at 3:15 PM
    muddog321
    FL
    Rear Diff capacity is 3.1 qts (or when it comes out the fill plug) but not 4.
    Front Diff 1.6 qt
    Transfer Case 1.1 qt
  19. Aug 30, 2022 at 7:30 PM
    Nctrucknut336
    Nctrucknut336 Member
    08 trd sport
    I ran into this same issue on my 08 with limited slip. Lucky I found that Mitsubishi makes a SAE 90 gl5 for the evo for around $15. My truck chatters at start if I use 75-90.
    Extra cheesy likes this.
  20. Aug 30, 2022 at 8:22 PM
    armartin
    armartin Member
    SoCal
    06 DCSB PreRunner
