Gear ratio chart meaning
Discussion in 'Wheels & Tires' started by JimBeam, Aug 26, 2008.
  1. Aug 26, 2008 at 6:32 PM
    JimBeam
    JimBeam [OP] BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    ok...in the pic i have circled a section in red...what do all those numbers mean and how should i read that?
  2. Aug 26, 2008 at 6:35 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    the top number is the gear ratio...and the bottom number is how many revolutions it would spin in a minute at 65mph
  3. Aug 26, 2008 at 6:37 PM
    JimBeam
    JB
    2015 Tundra
    but the different colors and teh words factory ratios, increased power etc throw me off
  4. Aug 26, 2008 at 6:42 PM
    The_Hodge
    SC
    well the green means the different options from the factory....the higher gears will give more power...ie crawling....and the lowers spin slower apparently and i dunno how they'd determine better fuel mileage...but i think thats how it goes
  5. Aug 26, 2008 at 6:45 PM
    JimBeam
    JB
    2015 Tundra
    ok so its saying that if i switched to these tires and switched to 5.29 gears id get more power...however if i switch to something like 3.73s id get better mileage out of them?
    and that my current 4.56 is a good middle ground point for the 255/85s?
  6. Aug 26, 2008 at 6:46 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    like hodge said, the green in our tire calculator is in the range that the factory would normally set your gear ratio at (and below each gear ratio would be the resulting RPMs @ 65mph). if your gear ratio was set in the yellow range you'd have better mileage but sacrifice some power. and red range gives you more power for towing and other things but sacrifices your mpg.
  7. Aug 26, 2008 at 6:50 PM
    JimBeam
    JB
    2015 Tundra
    thanks guys!
  8. Aug 26, 2008 at 7:07 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
