Gear Ratio
Discussion in '2nd Gen. Tacomas' started by ochoa104, Jun 25, 2007.
  1. Jun 25, 2007 at 7:06 PM
    ochoa104
    ochoa104 [OP] Member
    I was wondering if anyone could help me out. My truck has a 6" pro comp suspension lift with a 3" inch body lift. Since losing the original take off speed and fuel economy (running 35's) I've been looking to get it back. I’m going to re-gear my truck but before doing so I was wondering if anyone could give me some advice.
  2. Jun 25, 2007 at 7:47 PM
    Dominant967
    Dominant967 Well-Known Member
  3. Jun 25, 2007 at 8:43 PM
    ochoa104
    It would be perfect but I need something less expensive.
  4. Jun 26, 2007 at 8:38 AM
    MarkC
    MarkC Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    deckplate mod, intake, exhaust, TB spacer, all of these will give you a little somthing but to get any real power SC or turbo is the only way to go. also you lose 5% of your MPG with every 3 or 6 (not exactly sure) inches of lift.. gears should give you most everything back except that 5%
