Gear Ratio?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jalsum, Dec 13, 2011.
  1. Dec 13, 2011 at 7:36 PM
    jalsum
    jalsum [OP] Member
    reno nv
    97 tacoma S/C LT
    What is the correct way of figuring out your rear gear ratio? I'm looking for my 97 Tacoma 3.4L 4x4 non abs...Thanks!
  2. Dec 13, 2011 at 7:52 PM
    jalsum
    jalsum [OP] Member
    reno nv
    97 tacoma S/C LT
    Winner! Thanks!
  3. Dec 19, 2011 at 7:31 PM
    jalsum
    jalsum [OP] Member
    reno nv
    97 tacoma S/C LT
    Ok I have stock 3:91 gears, I'm in the process of collecting parts to make my truck long travel. I was wondering if i should stick with this ratio. my truck is 4x4 , supercharged and running 33's. The truck sees 75% pavement, and 25% off road. Should I go lower ratio, like 4:56's?
    Thanks!
  4. Dec 19, 2011 at 7:37 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    4.56 would be ideal
  5. Dec 19, 2011 at 11:18 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Id go 4.88s. I have read a bit on this and ppl are usually much happier with 4.88s then 4.56s. Either one would be much better tho.
  6. Dec 20, 2011 at 8:02 AM
    SPOTSONTROUT
    SPOTSONTROUT Well-Known Member
    ROB
    SOUTHERN ONTARIO CANADA
    03 TRD Stolen
    OME 882,DAKAR LEAF PAC WITH ADDA LEAF,285 TOYO OPEN COUNTRY MT,RACELINE RENAGADES,DECK PLATE MOD, MANUAL HUB CONVERSION
    If I go to 4:88 do you get the power and mpg back that you lose from instaling 33" tires?
  7. Dec 20, 2011 at 8:03 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    you get more power, mpg not so much
  8. Dec 20, 2011 at 8:21 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    4.88s i believe are suppose to put you back closer to stock ratios. closer to 4.10 then 3.90 tho
  9. Dec 20, 2011 at 8:48 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    i thought 4.56 with 33s would almost put him right on stock and 4.88 would be more power than stock?
  10. Dec 20, 2011 at 9:04 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
