gear ratio?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbp68, May 17, 2009.
  1. May 17, 2009 at 8:32 PM
    kbp68
    kbp68 [OP] hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    2006 DC4x4 TRD Off Road 4.0V6 6spd. Manual trans,factory tow pkg...anyone know the gear ratio? :confused::notsure: Just road tested with my new 3300# travel trailer and it seems a little long legged. I'm worried about burning the clutch and am wondering if a gear swap is in order.
  2. May 17, 2009 at 8:42 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i think its 3.73
  3. May 17, 2009 at 9:44 PM
    AZsand
    AZsand Well-Known Member
    3.73 on the 4.0
    4.10 on the 2.7
  4. May 17, 2009 at 10:31 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    ^ What he said
  5. May 18, 2009 at 8:15 AM
    kbp68
    B.C.
    TRD Off Road DC/SB
    Thanx guys. Anyone else towing with the six speed? Any problems?
  6. May 18, 2009 at 1:13 PM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Most towing, I generally pull only 1500lb or less utility trailer. Gearing perfect.
    Have pulled 5000 lb and 4000 lb boat. 1st is very short unloaded, but was great towing heavy. However going to 2nd seems tall, you really got to rev her out making the change to 2nd, esp climbing.
    Also if you normally run regular gas, when u tow put in Premium. Gain few hp & 12ft/lbs when u need it and helps offset $ with better mpg.
  7. May 18, 2009 at 1:50 PM
    tomballos
    tomballos Member
    Hyde Park, NY
    08 SR5, TRD
    Westin Chromed Nerf and Brush Bars, K&N CAI, Helix Power Plus
    I'm curious if my 2008 Access Cab 4x4 4.0 V6 A-Trans would also have the 3.73 rear gearing as it also has the factory installed hitch. I bought it used and can't seem to find this detail. Anyone know? Or better yet anyone know where I may find a copy of the vehicle window sticker?
  8. May 18, 2009 at 1:53 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    low range anyone? I know someone did a mod to make it 2 low, I used to do that in my old ranger. If you're towing anything that big, I wouldn't be worried about speed, thats for sure
