gear swap 2001 4x4?????
Discussion in '1st Gen. Tacomas (1995-2004)' started by shepnuts, Oct 5, 2010.
  1. Oct 5, 2010 at 7:09 PM
    shepnuts
    shepnuts [OP] Member
    I had a major mechanical failure in the motor on my 01 tacoma recently while towing my boat. I live on the Big Island of Hawaii, and there is hardly any flat land here. From what we can tell, the timing belt broke and I destroyed a valve??? (changed the timing belt, etc... when i got the truck in Texas, had 120k). It now has 175k. About to drop a motor from a junker with 75k in her. I will upgrade to a centerforce clutch, and was kicking around the idea of putting lower gears in the truck for better towing. How much of a bitch is it to do this??? Guess it depends on your mechanical skills, right....?
    Anyone tow much with this style tacoma? My boat probably weighs like 4000lbs or so. Too much?? It was pulling/stopping it no problem. I dont want to destroy this motor as well, nor do i want to buy another big ass truck.
    Any advice would be appreciated. Aloha!
  2. Oct 5, 2010 at 11:34 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I wouldn't try doing gears your self unless you know what your doing. My truck has never been in the shop, I do everything myself since I used to work at a shop. I don't mind doing the timing belt myself & other motor work but when I regear I will be taking it to someone who knows what they're doing.
    Regearing requires proper shimming or it will cause whining & premature wear and/or failure. Don't go cheap on the gears either. Also don't forget since your 4x4 you'll have to do front & rear or bad things will happen if you engage 4x4 with only the rear end regeared.
