Gear whine at 25 and 55
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tweaker, Jun 22, 2008.
  1. Jun 22, 2008 at 12:56 PM
    tweaker
    tweaker [OP] New Member
    Livermore, CA
    Tacoma
    I have an 08 std cab 4cyl automatic. At 25 mph when coasting or with mild acceleration I hear a very annoying apparent gear whine that seems to be coming from the rear end. It happens again between 50 and 60 mph only louder. I dropped it off for service and the tech wrote up "No abnormal noises heard". Is this a Tacoma trait?
  2. Jun 22, 2008 at 1:25 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    I would take it back and someone go for a drive to hear the noise Toyota has a new tsb out for just such a noise T-SB-0076-08 the title is Rear Differential Whine or Howling Noise at Highway Speeds dated may 29 2008. Hope that helps;)
  3. Jul 1, 2008 at 8:26 PM
    tweaker
    Livermore, CA
    Tacoma
    I went back and took the tech for a ride (slight upgrade at 53 mph). Parts are on order.
  4. Jul 1, 2008 at 8:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it may also be a good idea to drain the factory fill and put in some good stuff like mobil1 75w90 or royal purple severe gear 75w90......awesome lubrication, and probably a bit better than regular 80w90............and it may make the rear end run a bit cooler. just a thought.:)
  5. Jul 25, 2009 at 11:31 AM
    tellico
    tellico Member
    4 cyl
    I had the whine/howl TSB installed in my 08 Reg Cab 4 cyl Tacoma and I still get a slight whine/howl. Service manager says this is normal and occurs in all Tacomas. Should I believe him?
