Gearing to 4:88 for more power?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1gibson, Nov 10, 2018.
  1. Nov 10, 2018 at 7:49 AM
    1gibson
    1gibson [OP] New Member
    Western NC
    2002 green Tacoma
    Brush guard and 20” light bar
    new member here... I hav an 02 Tacoma. 2.7 auto. I am running 265/72/16’s on it now it is geared 4:56 now. I live in western NC mountains and it seems a little weak here in the mountain roads. I am looking into re gearing to 4:88 to get a little more power Not looking for crawler gear. losing top end isn’t a problem either, just want to give it some balls. Any suggestions???? Thanks
  2. Nov 10, 2018 at 8:22 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    If you mean 265/75R16 then we have the same truck, and I know how slow it is.
    The cheapest 4.88 gears and master rebuild kit is about $1,000. The cheapest gear install quote I got was another $1,000. Expect to pay $2,000-$3,000 depending on who you use to install the gears for you.
    This is for front and rear differentials. PreRunner/RWD is cheaper.
    tcBob likes this.
  3. Nov 10, 2018 at 8:30 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    :boink:
    Revolution Gear & Axle - Toyota Tacoma 95-04, Tundra 00-06 W/out Factory Locker (8.4/7.5reverse) 4.88 Gear Package Front & Rear Gears and Master Kits https://www.amazon.com/dp/B01ETJQTX4/ref=cm_sw_r_cp_apa_yDW5Bb7N7CQNG
    If you pull the thirds you can find labor for much less, $200 per third or so.
    $800 + 400 labor + 100 for fluids and other BS or so.
    you can get out the door for much less if you are able to put in the work of removing and installing thirds yourself
    tcBob likes this.
  4. Nov 10, 2018 at 8:52 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Have you found someone who will do a gear install for $400 labor? That price I was quoted was given by a small independent shop in Arizona, ECGS charges two times as much. I still have to send both thirds in.
  5. Nov 10, 2018 at 8:53 AM
    Wulf
    rock raisin
    Yes, I have someone local to me that will who I found through TW. If you ask around you can probably find a guy who does them on the side to make some extra money.
  6. Nov 10, 2018 at 8:55 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Have you used them? I’m looking for something cheaper.
  7. Nov 10, 2018 at 9:15 AM
    02hilux
    Planet: EARTH
    There's a local shop here in Clovis, CA that charge 250 per diff for labor. Had well over 10 diff built by him.
    Wulf likes this.
  8. Nov 10, 2018 at 9:36 AM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    pray4surf likes this.
  9. Nov 10, 2018 at 9:50 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    OP lives 5 hours from ECGS, Id just spend a day and go out to Raleigh and have it done by the best.
  10. Nov 10, 2018 at 9:54 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Lots of issues coming from ECGS diffs if you look around.
    I wouldn't trust them to setup mine.
    Speedytech7 and Fernando like this.
  11. Nov 10, 2018 at 9:56 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Weird. A lot of drivetrain shops around here use there stuff.
  12. Nov 10, 2018 at 10:47 AM
    Wulf
    rock raisin
    I have not but plan to.
  13. Nov 10, 2018 at 10:50 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    What’s the name?
  14. Nov 10, 2018 at 10:51 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s who I got the quote from. He quoted me $820
  15. Nov 10, 2018 at 10:59 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Technically you can send any 3rd in or wait till you receive the 3rd before sending yours in. And they will send you a freshly built one.
    You have to send the front in though. Atleast for ECGS
  16. Nov 10, 2018 at 11:22 AM
    1gibson
    Western NC
    2002 green Tacoma
    I was hoping that Toyota had a factory gear close to 4:88 that I could get from a salvage yard. Do they have anything close to that
  17. Nov 10, 2018 at 11:22 AM
    Wulf
    rock raisin
    4.56 is the closest factory ratio.
  18. Nov 10, 2018 at 11:58 AM
    1gibson
    Western NC
    2002 green Tacoma
    Ok thanks
  19. Nov 10, 2018 at 12:02 PM
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    Mine was $1705.00
  20. Nov 10, 2018 at 5:32 PM
    02hilux
    Planet: EARTH
    Northside4x4 in Clovis, CA
