gears
Discussion in '1st Gen. Tacomas (1995-2004)' started by beach_yota03, Aug 21, 2010.
  1. Aug 21, 2010 at 7:09 PM
    beach_yota03
    beach_yota03 [OP] Well-Known Member
    jonny
    wilmington, north carolina
    03 taco sr5
    what gears come stock in a 03 taco trd package
  2. Aug 21, 2010 at 8:44 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Most likely 4.10s if you have the v6.
  3. Aug 21, 2010 at 11:45 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    To be sure, look on the little capacities placard on your drivers door jamb. Somewhere near the vin on it there is a 4 digit number. For example, mine says A02A. That's your axle code. There's a table somewhere on here that has what each of these digits means. I believe if i remember right mine's a 7.5" 3.58 2 pinion open diff.
  4. Aug 22, 2010 at 6:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Only the TRD's had 4.10's
  5. Aug 22, 2010 at 6:54 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
  6. Aug 22, 2010 at 6:53 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hhmmm.... I'll accept that. Can't tell if the OP is a TRD or not. Were the rest of the v6s 3.90 gears?
  7. Aug 22, 2010 at 8:23 PM
    MowTaco
    Kansas
  8. Aug 22, 2010 at 8:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depends on the gear code. I think there were about 7 different gear ratios for the first gens...
