Gears?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crux, Mar 7, 2019.
would you recommend regearing?
  1. Heck Yeah!
    3 vote(s)
    25.0%
  2. They help a little
    2 vote(s)
    16.7%
  3. They help but damn they are expensive
    5 vote(s)
    41.7%
  4. Not really
    0 vote(s)
    0.0%
  5. Heck No
    2 vote(s)
    16.7%
  1. Mar 7, 2019 at 4:17 PM
    crux
    crux [OP] Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    Gears, do they help with 33" tires?
    Mostly interested in MPG?
    Other areas of interest would be acceleration both in town and highway.
    Considering going from stock to 4.30 gears on a double cab.
  2. Mar 7, 2019 at 4:59 PM
    KLiK
    KLiK Active Member
    Kim
    Central California
    2011 4x4 Standard cab Barcelona Red Tacoma 4 banger automatic. Basic everything else
    OME 885, Toytec AAL with OME shocks, Stainless steel extended brake lines, 4:56 gearing, 255/85 on stock rims, ARB air locker front, Eaton True track rear. Off Road hide a bumper, 12,000#HF winch
    I have 2011 single cab, 4x4, regeared to 4:56, ARB Locker front, Eaton true track rear.
    I haven’t measured mileage but I go by 200 miles a tank whether needed or not.
    Tires 255/85 on stock rims (Maxis Bighorns)
    If I was to do regear again I’d go 4:88 since I have the 4banger.
    Had a shop do the diff work and they put 85/140 gear oil in.
  3. Mar 7, 2019 at 5:14 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Yes they will help with acceleration, mpg may be a different issue.
    revtune likes this.
  4. Mar 9, 2019 at 7:34 AM
    KJP
    KJP Well-Known Member
    Kevin
    2013 Tacoma DCLB
    Elka coilovers, supercharged, 4.56 gears, ARB front and rear, 255/75/17 BFG, other stuff that weighs a lot
    4.56 with 265 tires -32 inch tires. My fuel mileage is slightly higher to what I was stock, but I have a 300 pound front bumper and winch, 150 pound rock sliders and a bunch of other weight now, so I feel the gears likely didn't hurt my mileage at all with the larger tires. If I was going 33 inch tires I'd be tempted to go 4.88. But if you are often on 80mph freeways then maybe 4.56. Was the right change for me - I have the 4.0 and auto tranny though. If you are standard I'm not sure as stock is 4.10 gears so 4.3 likely wouldn't be worth it. (Does anyone even make 4.30?)
  5. Mar 9, 2019 at 7:39 AM
    Pigpen
    Dan
    Northwest Montana
    My 4.0 handles 255/85/16 really well except when towing a load at highway speeds. I wouldn't mind a little more torque off road too, but I've learned to drive it as is. I get 18 mpg for most of my driving in the summer. Manual transmission is a factor here.
  6. Mar 14, 2019 at 7:36 PM
    revtune
    revtune Dreaming of a 4.7 Tacoma
    Houston
    2007 Tacoma DCLB 4x2 4.0
    5100 front struts set on top perch trd sport coils Spc upper control arms 5100 rear shocks toytec add a leaf 1 inch rear block Longer U-bolts 17x7 SR5 (2014) 4Runner Wheels p285/70/17 Falken At3w AFE Stage 2 si with volant ram scoop MAF Calibrator 4.30 gears Undercover bed cap Weathertech floor liners
    I have an auto 2wd with 4.30 gears. I run 295/70/17 hankook at tires and combined with the wheel I’ve got 90-95 lbs per corner. I also carry a constant 300 lbs. worth of tools. Sometimes I actually feel overgeared for highway driving. Give or take a few rpm, I’m turning 2150@65, 2270@70 and 2400@75. From my experience with 33’s, 4.10 gears is highly recommended for daily driving, you won’t be disappointed. 4.30 & 4.56 is good for off-roading. My mpg with lift, big tires and tools has always sucked with or without gears.
    b_r_o likes this.
  7. Mar 15, 2019 at 6:16 AM
    revtune
    Houston
    I would also like to add, for the folks with a manual transmission 4.0 thinking about a gear change. you might actually find your truck livable with stock gears because of the lower highway rpms. Of course this is taking into consideration that you don’t go to crazy with your tire selection. You would need to stick with an AT tire in the 285/295 variety. If you start throwing mud tires into the equation, you can pretty much forgot this recommendation. For auto tranny 4.0 just go with 4.10 gears with a tru trac LSD and call it a day.
    Kolter45 and crux[OP] like this.
