geekhouse23's "LIFE'S WAITING TO BEGIN" Overland & Home build and all the Adventures in between!
Discussion in '2nd Gen. Builds (2005-2015)' started by geekhouse23, Nov 11, 2013.
  1. Dec 22, 2015 at 12:26 PM
    #1101
    geekhouse23
    geekhouse23 [OP] The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I thought that too. Seems like you would need it to figure out where to mount it, angles etc..
  2. Dec 22, 2015 at 12:27 PM
    #1102
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    The shock towers are supposed to be a 9 degree angle forward (both sides) but on one side it hits the bed so we could only get it to 7 degrees. Not a big difference but little things like that, i'd hate for you to get it welded up then try to put the bed on and find out it hits the shock towers.
  3. Dec 22, 2015 at 12:31 PM
    #1103
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    @SoutheastOverland can y'all help him out with what degree and angle and all that is needed for the BAMF shock relocation
  4. Dec 22, 2015 at 12:32 PM
    #1104
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
  5. Dec 22, 2015 at 12:39 PM
    #1105
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Yes you don't need to pull the bed, i was just told that it just makes the prep easier and faster. I was told by @JLee that before you go and weld it down, put the bed on to make sure it still fits and make adjustments if needed.
    I'm pulling the bed since I'll be doing the relocate, shackle flip, plating the frame and building a new rear xmember.
    Edit: I do realize that I'm very fortunate to have access to a fabrication shop 2 miles from my house and a wealth of knowledge of my friends. Even with all of this, its going to be a shit ton of work.
  6. Dec 22, 2015 at 12:43 PM
    #1106
    geekhouse23
    :bowdown:
    Thanks dude! I need to keep an eye on JLee's website for a deal on these..I'd probably want a pre-welded kit to make it easier and smoother..If I can get a good deal on a set, I would be more motivated to do it together or shortly after the shackle flip :boink:
    You have all the more reason to pull the bed haha that sounds sick dude! can't wait to see it done!
    Acerwin likes this.
  7. Dec 22, 2015 at 12:45 PM
    #1107
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Thats what I did! 15% off I think is his deal. Yeah I would definitely go with pre welded kit, his welds are really good and saves you a bunch of time for not much more money.
  8. Dec 22, 2015 at 12:48 PM
    #1108
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I got mine not welded together. The reason I did that was soi T could be worked with when trying to get welded on the truck. @SoutheastOverland did all mine and I'm happy with the results that they did
    SoutheastOverland likes this.
  9. Dec 22, 2015 at 12:49 PM
    #1109
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    @geekhouse23
    If your going to pull the bed just do it for removal of the stock mounts and the final welding. Make sure the bed is in place when tacking the towers as you will have very little clearance between the tower and the bed. I like to put them at 9 degrees it's just enough forward to help clear the tire but no so far that your messing with the dampening of the shock. Ideally you want them at 0 degrees but that puts you right at the tallest part of the tire so it doesn't always work for guys that want to still flex out.
  10. Dec 22, 2015 at 12:53 PM
    #1110
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
  11. Dec 22, 2015 at 5:40 PM
    #1111
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Did your Prinsu cab rack come with 7 or 8 cross bars? Mine came with 7 (6 regular and 1 for the wind deflector) but i'm thinking I need another one for the light bar to mount to
  12. Dec 22, 2015 at 5:50 PM
    #1112
    geekhouse23
    So I have the old school one that came without a cutout option and 2 crossbars for the deflector. So when I swapped to the cutout deflector, I had an extra cross bar to use for the LED bar.
  13. Dec 22, 2015 at 5:50 PM
    #1113
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Oh okay.. Hmm. Time to do some thinking then
  14. Dec 22, 2015 at 5:52 PM
    #1114
    geekhouse23
    If I had an extra one, I would send it to you.
  15. Dec 22, 2015 at 6:14 PM
    #1115
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Haha thanks man. Im thinking about this kind of setup
  16. Dec 22, 2015 at 6:15 PM
    #1116
    geekhouse23
    That should work just fine :thumbsup: what bar are you planning on running?
  17. Dec 22, 2015 at 6:16 PM
    #1117
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Rigid SR2 40". Just thinking how to make those brackets.. think if I bend an aluminum piece to that it'll be strong enough?
  18. Dec 22, 2015 at 6:18 PM
    #1118
    geekhouse23
    I would personally go with steel..just my .02
  19. Dec 22, 2015 at 6:20 PM
    #1119
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Hmm.. Probably right
  20. Dec 22, 2015 at 6:26 PM
    #1120
    geekhouse23
    Nothing wrong with overkill for brackets
