Gen 2 auto trans temp gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krohsis, Mar 20, 2015.
  1. Mar 20, 2015 at 10:47 AM
    Krohsis
    Krohsis [OP] Active Member
    So, over the last few days I think I have read nearly all the posts on auto trans temp gauge systems using the OBD connector. Some will say some aftermarket products work in the Tacoma, then others will say the same system doesn't work. I hate to start a new thread, but I just want to know, does anyone make a gauge system for auto trans temp that uses the OBD connector that shows auto trans temps for a 2014 Tacoma? If not, what old school method are you using and from what manufacturer?
    Thanks
  2. Mar 20, 2015 at 10:51 AM
    taco211
    taco211 Well-Known Member
    socal
  3. Mar 20, 2015 at 12:28 PM
    Krohsis
    Ok, great! So are they plug and play, or do they need to be programmed? If they need to be programmed is there a sticky for that? I saw lots of postings about programming in the different threads, but some of the suggested programming posts were in conflict with each other. I didn't see a sticky, so I'm guessing there isn't one, unless it's inside another? Is there a preference between the Scangauge II or the Ultragauge?
    Thanks again!!
  4. Mar 20, 2015 at 1:01 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    scangauge can be programmed with a new x-gauge (or two)
    to read two tranny temps, the hot side and cold side
    ultragauge can supposedly but the threads about doing it I am unsure of
    search
    the scangauge x-gauge parameters are in here somewhere
    here
    Transmission Temperature 1 (Degrees F) 2010+
    TXD: 07E02182
    RXF: 046105820000
    RXD: 2808
    MTH: 00090005FFD8
    NAM: TF1
    Transmission Temperature 2 (Degrees F) 2010+
    TXD: 07E02182
    RXF: 046105820000
    RXD: 3808
    MTH: 00090005FFD8
    NAM: TF2
  5. Mar 20, 2015 at 1:44 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    Codes for 2012-2015 Trans temps *F:
    TDATA: 07E02182
    MTCH: 6182
    RPOS: 2808
    RCTRL:21
    TCTRL:92
    X: 0009
    /: 0005
    +: FFD8
    Output format: 00
    Left/Right is 31
  6. Mar 20, 2015 at 1:44 PM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    For ultragauge
  7. Mar 20, 2015 at 1:50 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  8. Mar 20, 2015 at 9:52 PM
    Krohsis
    Thanks for all the input guys!
    Holy Hand Grenade, thanks for the link to the video, I'll check it out when I get home.
