Gen 3 Towing Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Jan 28, 2016.
  1. Feb 27, 2016 at 5:03 AM
    #41
    aggie77
    aggie77 Well-Known Member
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Lund Nerf Bars Auto tailgate unlock
    Scroll back up to post #33.
    Joe jaramillo likes this.
  2. Feb 27, 2016 at 5:07 AM
    #42
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Do you plan to take the trailer to a scale at some point to get accurate weight measurements of the whole trailer and tongue weight? I've been let to believe that the dry weight quoted by most manufacturers are rarely correct (and usually they are understating the actuals).
  3. Feb 27, 2016 at 6:07 AM
    #43
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    Yeah, I went back and read rest of the way through. How hard was it removing the panels without the clip tool? I wouldn't want to accidentally break any of them.
  4. Feb 27, 2016 at 6:19 AM
    #44
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    The kick plate on the floor board doesn't require any special tools. There is a plastic nut holding it to the floor that you can unscrew with your fingers. Once the nut is off, just lift the plate off the stud and pull it away. The picture I posted with the arrow pointing to the location of the wiring harness connector is a view with the panel off. The jumper cable I ordered plugs into that harness connector on one end and the other end plugs into the P3 controller.
    Removing the small cubby holder (some call it a key holder, some a place to put gum wrappers) was as simple as using a small screwdriver to go under the lip and pop it out. I then cut a hole in the back of the cubby holder so the wires could come through, popped it back into the dash, connected the controller to the jumper through the hole and pressed the controller into the holder. It's a tight fit but holds the controller securely without breaking anything.
    Some more details are here: https://www.tacomaworld.com/threads/trailer-brake-controller.398124/page-5#post-11518030
    Mr. Torgue likes this.
  5. Feb 27, 2016 at 7:32 AM
    #45
    travis5049
    travis5049 Well-Known Member
    New Braunfels, Tx
    2014 4 wheel drive
    Upgraded to the TRD 17" rims and added weld on rock sliders with Bed coat material, Billsteins in the front set at 1.75, tinted windows.
    aggie77 is that cobra yours? I'm building a car trailer with electric brakes to specifically haul that same car to the track (H2R). I also have a 2008 Shelby GT500 rag top.
  6. Feb 27, 2016 at 8:05 AM
    #46
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    I used to be. I built it in 1994 and sold it in 2005 to someone in Lake Tahoe when we moved to Massachusetts. Now that we've moved back to Texas I kinda wish I had it again. It was a Lone Star Classics kit. I chose them because they were initially located in Keller about 5 miles from my house at the time. They moved a bit west to a building at Hicks Airfield later and have since been sold to Ultimate Classic Cars. It took about 3 months to build and another month in a body shop for prep and paint.
    Mine had a 428 mated to a top loader out of a Cobra Jet and a 9" with 31 spline axles. The latter was probably overkill as the car only weighed 2,500 pounds. The bottom end was built up by a racing shop and I did the top end with a Crower cam profile for a wide torque band. Harland Sharp roller rockers and Edelbrock aluminum heads and intake that I ported and polished. On a chassis dyno it developed 450 lb-ft of torque starting at 2,000 RPM and topped out around 500. When autocross racing I rarely had to shift - I could use 1st or 2nd on most any course. The original gears in the pumpkin were 3.00 and I could get to 60MPH in first gear. I changed that to 3.73 and it was too scary to drive and eventually compromised on 3.33. It would run the quarter in the low 11s at 128MPH with street tires. I had to run 91 octane pump gas and it got 10 MPG at best. Regardless, it was fun to drive.
  7. Feb 27, 2016 at 8:56 AM
    #47
    thors.hammer
    thors.hammer Well-Known Member
    Oops, missed that. Thanks.
  8. Feb 27, 2016 at 9:14 AM
    #48
    thors.hammer
    You're just using the truck brakes, correct? Thats my normal setup with my 2nd gen and I don't feel it needs a trailer brake controller and brakes installed on the trailer.
  9. Feb 27, 2016 at 9:16 AM
    #49
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    I may be wrong but think the owner's manual recommends a brake controller when towing more that 1K pounds and a WD hitch over 5K.
    NTSALL4 and Booney64 like this.
  10. Feb 27, 2016 at 9:21 AM
    #50
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    I was mistaken. Here's a snip from page 171:
  11. Feb 27, 2016 at 1:18 PM
    #51
    Jaycen
    Jaycen Well-Known Member
    Jay
    Worcester, MA
    2022 TRD PRO...the ugly Electric Lime color
    here is what I tow...
    1896872_10202720465910633_54051882392968_7003e26b4d766d1e4c7e7953da074c385b3758bc.jpg
    tacomatime, mrjbq and Kevindust like this.
  12. Feb 27, 2016 at 1:22 PM
    #52
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    I'm glad i'm not the only one who tows a big ass TT with my Taco...Nice TT...
  13. Feb 27, 2016 at 1:23 PM
    #53
    Jaycen
    Jay
    Worcester, MA
    Its not that big 26 foot. Dry weight on the inside of the door is 4800#
  14. Feb 27, 2016 at 1:27 PM
    #54
    gmann1972
    Greg
    Rhode Island
    I have a 244BH KZ Sportsmen, dry is 4400#, overall length is 26'5"...Packed for a trip is 5600# tanks empty...I noticed your from Worcester, where do you normally camp? we go up to your area occasionally to Pine Achers...
  15. Feb 27, 2016 at 1:34 PM
    #55
    Jaycen
    Jay
    Worcester, MA
    I find pine acres expensive for what it is. But you really get what you pay for. We really like Moose Hillock in Lake George NY, lots do do for the 10 and 5 year olds, they have a location in NH too. We don't really go anywhere specific, kinda spur of the moment. KOA mystic, We have been to Fishermans Campground in RI, my parents lived on Great Island for years. I like to be near the water, since they put the pools in at Bourne Scenic park, we like that... My wife runs the spartan races, so we chase her around newengland in the summer. River bend in Oneco CT, isn't bad. We really just go anywhere...
  16. Feb 27, 2016 at 1:39 PM
    #56
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Have either of you taken your trailers to a scale to have them weighed? I haven't seen a lot of trailers that were very close to the dry weight.
    Thx
  17. Feb 27, 2016 at 1:39 PM
    #57
    gmann1972
    Greg
    Rhode Island
    Us too, we really go everywhere and anywhere, OMG I can't believe you said Moose Hillock...my wife and I absolutely love both of those locations, they are by far the best campground around, that is our preferred. We only go to Pine Achers for a quick weekend get away, and yes you are right, very expensive...This year we are headed to Niagara Falls / Canada for a week and Vermont for a week, and many long weekends...
  18. Feb 27, 2016 at 1:40 PM
    #58
    gmann1972
    Greg
    Rhode Island
    No not yet, that is on my to do list before the first trip this year...
  19. Feb 27, 2016 at 1:40 PM
    #59
    aggie77
    Georgetown, TX
    2016 Tacoma Ltd 4x4
    Or have either of you towed them up Mt. Washington? :) Used to live in Uxbridge.
  20. Feb 27, 2016 at 1:42 PM
    #60
    gmann1972
    Greg
    Rhode Island
    Oh YEAH, been up to the mountains in NH, Main, and Vermont...The truck does struggle a little but it does it...I usually need to down shift, but the truck does it like a champ..
