Gen 3 Towing Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJonn, Jan 28, 2016.
  1. Jul 5, 2018 at 11:53 AM
    #1381
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Nice! The new Zft2 tower on the NXTs is a home run. Great looking boat.
  2. Jul 5, 2018 at 11:55 AM
    #1382
    Tacoaric
    Dallas, Texas
    Can’t go wrong with the XT line. If you have any questions let me know, I have been around the brand my whole life and work very closely (and sometimes for) my local Mastercraft dealer. Check out Mastercraft.com/teamtalk.
    phsycle[QUOTED] likes this.
  3. Jul 12, 2018 at 9:52 AM
    #1383
    dherr2012
    dherr2012 Member
    17 Tacoma Off-Road
    What was the width of this trailer and what did you do for your side mirrors? Did you use extenders or just the oem mirrors? I'm finding that these travel trailers tend to be wider than the trucks at this length. I'm going to be towing a unit very similar to the one you pulled with a tongue weight of 560 pounds using the WDH and sway control bars. I really liked reading this since I haven't found anyone else pulling a unit comparable to what I'm going to be in a few weeks. I just bought a set of mirror extenders that I need to pick up yet. Hoping these will work well. Since the Gen3 trucks are only 75.2" wide with the mirrors and many units are 96" wide.
  4. Jul 13, 2018 at 8:41 PM
    #1384
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    did you have it in "s" mode ? with that boat should be hunting gears in s mode. if your towing in d mode then that makes sense. that's a good way to burn up the torque converter. always tow in s mode.
  5. Aug 1, 2018 at 3:40 PM
    #1385
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    Just under 800 miles last weekend. Was impressed with how well it towed. 12 mpg doing 65-70
    TOMRR likes this.
  6. Aug 1, 2018 at 4:20 PM
    #1386
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    squatting pretty good there.
    joestacos likes this.
  7. Aug 11, 2018 at 9:26 AM
    #1387
    thepinktaco
    Cody
    Orange, MA
    Think it’s the way it’s sitting. Rear only dropped 1” loaded up. It also has 1.5” lift in the front only.
  8. Aug 13, 2018 at 10:11 PM
    #1388
    tow-coma
    tow-coma Well-Known Member
    I don't think I've posted in here yet.
    We tow a 14 foot, 3600 pound (dry) Dune Sport toy hauler. They only do custom builds so we only paid for what we wanted and it came out to less money than the same prebuilt trailer from other manufacturers. We have 15k AC / heat pump, largest single door fridge/freezer, two couch/beds, electric queen bunk, dual propane, dual battery, stove, microwave, lots of extra cabinets, and probably other stuff I'm forgetting. We didn't get an oven, awning, built in generator, TV. We have a Honda EU3000is that powers the AC and isn't even maxing rpm to do it. It came with 3 50 gallon tanks and we sometimes carry 20 extra gallons of fresh water if we to Underground exploring events where we need showers each night after getting dirty. I use a 10k Curt WDH and friction sway bar which was free with our trailer when we bought it. I run the bars nowhere near level so I'm not worried that ita rated too strong for the weight.
    I have installed a large aftermarket transmission fluid cooler in line with the stock unit. I hit 235F in second and third gear when the torque converter is unlocked. If I pin the thermostat open, it only climbs to about 210F. You guys should consider pinning the thermostat when towing.
    This is a full 96 inches wide inside so the thing is much wider than the truck. I have some cheap Amazon mirrors that help me see around it. It's also a sail due to its boxy and short shape. Every truck that passes me pulls me into it and then pushes me away. It's fun...
    We are usually towing to remote places around Mojave and Death Valley or up Highway 62 to Yucca Valley where the 2 hills are majorly steep and I have to slow down a bit and run in 2nd gear. I have crawled it along some rough mining roads in 4lo.
    Some dirt road
    https://www.instagram.com/p/BaVe9kMFdXc/?utm_source=ig_share_sheet&igshid=1j69dre6w5pvm
    The night be towed it home from Arizona where it was built
    https://www.instagram.com/p/BZJoUYeF-vy/?utm_source=ig_share_sheet&igshid=gufo6avkbzk9
    I removed the filter because it began to weep fluid slowly
    https://www.instagram.com/p/BY2AjspFIod/?utm_source=ig_share_sheet&igshid=1wopvq336gt4p
    The TV is sitting on top of a cabinet. We have not mounted it
    https://www.instagram.com/p/BZaaN-_lhW6/?utm_source=ig_share_sheet&igshid=1m91ugqbvi5hc
    Christmas in the desert
    https://www.instagram.com/p/BdEuqsyn-r1/?utm_source=ig_share_sheet&igshid=15qgrrvbyndui
    Mushu, joestacos and specter208 like this.
  9. Aug 13, 2018 at 10:12 PM
    #1389
    tow-coma
  10. Aug 14, 2018 at 1:07 PM
    #1390
    joestacos
    joestacos Ice cold rice water
    that1tacoguy
    CenCal
    17 Tacoma TRD Off Road
    Pro Driver inside
    CANT SEE PICS! But I want to!
    melikeymy beer likes this.
  11. Aug 14, 2018 at 1:39 PM
    #1391
    tow-coma
    Check them now
  12. Aug 14, 2018 at 9:26 PM
    #1392
    joestacos
    that1tacoguy
    CenCal
    Pro Driver inside
    SUPER SIKK!! Ive been following the page looking at the 12’&14 toyhaulers. Im stoked to see a Taco pulling one!
  13. Aug 15, 2018 at 1:16 AM
    #1393
    tow-coma
    Here is the inside before we organized it this weekend
    joestacos[QUOTED] likes this.
  14. Aug 15, 2018 at 8:04 AM
    #1394
    iamthewheelman
    iamthewheelman New Member
    Here is my 2017 TRD Sport 6 Speed Manual. I have a Tekonsha P3 and a Curt weight distribution hitch and I am pretty impressed with how the truck performs. The bed is loaded up with about 300lbs of various items as well, such as a spare set of wheels, tool box, fuel etc. The trailer weight is 1500lbs give or take a few hundred and the car weighs in at 2230lbs.
    My father just got a 2018 TRD Sport auto with the 6ft box and I am going to start towing with that as well. I am curious to see how it performs vs the manual. Just from driving his truck around I think the tranny is going to be kicking down very frequently.
  15. Aug 16, 2018 at 7:35 AM
    #1395
    MGM3Pedal
    MGM3Pedal Well-Known Member
    Rob
    Appalachian Mountains
    2017 MGM DCSB 6MT TRD Sport 4X4
    Hit and miss engines...
    G.T. likes this.
  16. Aug 21, 2018 at 6:50 AM
    #1396
    ridge
    ridge One Gear; No Fear
    North Carolina
    '17 TRD Sport DCSB M6
    MESO!
    New-to-me tractor needed new tires, so I calculated all the weight and decided the Tacoma could handle it... well, I may need to add those OME leafs sooner than I thought, but the Taco did well for its first heavy towing job!
    02Duck likes this.
  17. Aug 21, 2018 at 7:23 AM
    #1397
    phsycle
    phsycle Well-Known Member
    CA
    What's one of those thing weigh?
  18. Aug 21, 2018 at 7:41 AM
    #1398
    ridge
    North Carolina
    MESO!
    The tractor itself, with all fluids and rear tires w/ anti-freeze inside; is about 2300lbs, then add another 2000 for the trailer. It lightened the front end a bit and pushed mildly on braking (no trailer brakes on that one), but still controlled well and the MT didn't wheeze once. Adding an extra leaf out back and stiffening up the shocks would do wonders for towing that type of load.
  19. Aug 21, 2018 at 8:47 AM
    #1399
    dherr2012
    dherr2012 Member
    17 Tacoma Off-Road
    Update completed the trip with the 27’ travel trailer weighing in loaded maybe 5100lbs. Total combined at 10,200 lbs. towed great. Ran at 1700-2500 rpms. Avg 10mpg each way. Wouldn’t hesitate to do it again. Stopped on dime never had any issues. Using a Tekonsha 90160 Primus IQ Electronic Brake Control.
    Speeds were averaging between 55-60 headed south most of the time due to the weather. It was very heavy rains and windy. While traveling back 95N through VA and MD I was running 65-75mph and yes that still gave a good 10MPG. Brake controller was set to 13 and was a perfect match. One additional item I added was trailering mirrors. My trailer was 96" wide and of course the Tacoma was only 75.2" wide to the outside of the mirrors. So Pepboys had a great deal for mirrors at only $15/each. Strapped them on and down the road.
    Dctaconny and Pickupman2007 like this.
  20. Aug 21, 2018 at 9:58 AM
    #1400
    okichewy1
    okichewy1 Just chuggin' along!
    Ken
    Kimberly, Idaho
    2018 DCSB TRD Sport Quicksand
    Ultra Flex bed cover, TRD PRO Grille, 32" LED light under grille, Pop n' Lock on tailgate, OCD organizer for center console and glove box, LED bed lights, OEM bed mat, black TACOMA tailgate letters, LED illumination light package, black vinyl overlays for badges, OEM bed step, plasti-dipped front valance and mirrors, 15% tinted windows and sun strip, vinyl letters on dash, vinyl letters on tailgate handle and door sill protectors, TRD Pro shift knob, home-link rear view mirror, mountain vinyl decal above Tacoma on door, FN FX pro wheels, AVS bug deflector, AVS in-channel window vents, front bed rail, red line hood struts, LED interior lights, TRD Pro skid plate, slim line front license plate holder, CaliRaised LED Ditch light brackets with LED lights, Bilstein 5100's, OME 888's, Dakar HD leaf springs, cubby covers, CaliRaised LED Fog light kit,
    I have a 19' aluminum Tracker Targa V18 combo boat. With trailer it's supposed to be about 3900 lbs. I usually get about 22-23 mpg without and with the boat I get about 16-17 mpg with speeds up to about 70 on the highway living in the mountains in Idaho (about 3900' elevation). No issues what so ever with towing.
    Herniator likes this.
