General Cost of Converting Fog Lights To HID
Discussion in 'Lighting' started by Logan22, Jun 9, 2012.
  1. Jun 9, 2012 at 9:45 PM
    Logan22
    Logan22 [OP] Well-Known Member
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Tonneau Cover, Tube Steps, Kenwood Excelon KDC X895, Boston Acoustics Speakers, 12 Shallow Mount Rockford Fosgate punch p3s sub, Rockford Fosgate Punch 400 watt amp 18 in. xd spy's 285 60 18 terra grapplers
    About how much would it cost to do a retrofit for HID fog lights? How hard is this to do yourself? What are some good brands to consider? I would appreciate it if anyone posted pictures of having just HID fogs. I have piaa extreme white plus for headlights that I just bought recently and this is why I'm just thinking about the fogs. Thanks
  2. Jun 9, 2012 at 9:53 PM
    400lbGorilla
    400lbGorilla ^Son of a hamster, I smell of elderberries.
    T-LAM
    Ocean City, MD
    BSP 4X4 BASE
    Roof Rack, TRD exhaust, Hood Shield, Side Steps, 5% Tints, Tow Package, Bed Extender, Billies at 2.5, Toytec TSB AAL, Avid Offroad Bar, Cruise Control, Removed Sway, Hella 700s, 6000k HIDs, diff breather mod. DTRL, BHLM,Sockmonkyed.
    OP are you talking about putting in projectors in the fogs?
  3. Jun 9, 2012 at 10:40 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    If your talking about a "retrofit" then you mean converting them to projector then correct?? If so, look up member Jerez he recently did a true HID Retro in his fogs.
    However, if by retro you really meant just replace halogen bulbs for hids and ballasts, then you can get these full hid kits for $40-50 and they are plug and play. Its a 15 minute install if DONT know what your doing and 5 minutes if you do. OK maybe a little longer to make it look pretty but u get the idea. If you know how to change a light bulb you can do it :D
  4. Jun 9, 2012 at 11:46 PM
    400lbGorilla
    T-LAM
    Ocean City, MD
    BSP 4X4 BASE
  5. Jun 10, 2012 at 1:56 AM
    Hii
    Hii Well-Known Member
    Projectors in your fogs are pointless. It completely eliminates the purpose of a fog light
    Converting your stock fogs to HID is simple. Stay away from Xentec and onex or anything off eBay for that matter
  6. Jun 10, 2012 at 6:30 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You obviously have no idea what you're talking about... I put projectors in my fogs and they are the best fog lights I've ever had. You have very bright, focused light, very low to the road and a crisp cutoff so you don't get any glare back in your eyes.
    Here's a step by step on putting projectors in your fogs:
    http://www.tacomaworld.com/forum/lighting/187831-fog-light-retrofit.html
    Just throwing HID's into your stock fog lights results in a lot of glare and will make your fog lights pretty useless for foul weather.
  7. Jun 10, 2012 at 10:03 AM
    Hii
    I've always ran HIDs in my fogs on both my trucks. 3k in my old truck. Worked amazing in the fog. Drove 200 miles in a huge storm with just my fog lights on and I could see everything perfectly fine with the stock housings
  8. Jun 10, 2012 at 4:18 PM
    Pugga
    Massachusetts
    Did they have the metal shield under the bulb? Either way, I'd put money on my projectors being a hell of a lot more effective than a plug and play HID kit...
  9. Jun 10, 2012 at 4:39 PM
    Hii
    H10 bulbs (fog lights) don't come with metal shields. The only bulbs that come with metal shields are H4, 9004/7 and H13
  10. Jun 10, 2012 at 4:58 PM
    Pugga
    Massachusetts
    x2, which is exactly why plug and play HID kits aren't a good idea for fog lights if you actually want them to function as foul weather lights.
  11. Jun 12, 2012 at 8:45 AM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Thanks for all the responses and information, it was real helpful. I thought real hard about the HIDs but ended up going with some piaa extreme white plus fog lights to match my headlights.
