General Deals I Found - Through End Of May 2016 - Brakes & Rotors @ Advanced
Discussion in 'Deals & Coupons' started by TacoYes, Apr 20, 2016.
  1. Apr 20, 2016 at 10:45 PM
    TacoYes
    TacoYes [OP] Well-Known Member
    2011 Silver 2.5 Door
    Black Wheels, Grill, Running Boards
    Rather than starting new threads, figured I would just update old deals that have came and went. This new one is with Carquest Wearever Platinum break pads and rotors. After a rebate of $20 an axle and 15% off you should end up paying around $70 for front brakes and rotors. I haven't went through the full process of buying and sending in the rebate but just wanted to post this. Looks like this runs through the end of MAY 2016.
    I have no affiliation with any company(s) just always looking for decent deals to make car maintenance a manageable situation. I do a ton of driving so the items needed come more often.
    Below is the previous deal which is no longer available.
    Just found this on eBay; http://www.ebay.com/itm/90915-YZZD1...453062?hash=item3aa1d8f386:g:xuMAAOSwxYxU07HE
    10 Toyota Filters - Many different sizes. This link is for the YZZD1, there are also YZZD3 and at least three or four other sizes.
    You must put it on your cart to see the $40, its listed at $45
    Free Shipping
    Free 10 Drain Plug Gaskets
    Not sure how long it will last...
    Iron Ikaika and Mr.PowerTrays like this.
  2. Apr 20, 2016 at 11:47 PM
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
    What is the difference in D1 and D3?
  3. Apr 20, 2016 at 11:56 PM
    TacoYes
    I believe its the difference between the 2.7 and 4. Cannot confirm for sure. I think the D3 is bigger. I have a 2.7 and know the D1 is the correct one. You would have to put your truck into the search. Sorry, not much help, just don't want to steer you wrong.
  4. Apr 21, 2016 at 12:04 AM
    Ridgeline001
    Oregon
    2014 DCLB Sport 4wd
    I use the D3, but in a compatibility search both showed up. That is why I was wondering. Thanks for the reply, and I ordered mine.
  5. Apr 26, 2016 at 10:02 AM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Thanks, just bought a set, oil changes are going to be cheap between this deal and the Mobil 1 deal.
    TacoYes [OP] likes this.
  6. Apr 26, 2016 at 12:13 PM
    TacoYes
    Just did my $15 premium oil change (Mobil 1 extended, Toyota filter) this weekend, wow. It use to cost me almost $40 for each. After the rebate is gone it will be $30 (oil, filter, drain plug washer) Me likey.
  7. Apr 26, 2016 at 1:12 PM
    Daxdagr8t
    Daxdagr8t Well-Known Member
    Socal
    07 prerunner
    None
    Stock up on mobil 1. I usually get 6-8 5qts jug when there is a rebate using my parents, neighbors and cousin address. Trick is to let the first checks clear then submit new rebates since there is a two limit per household.
  8. Apr 26, 2016 at 10:38 PM
    TacoYes
    Found out this sale ends at the end of the month.
  9. Apr 26, 2016 at 11:07 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2010 Double cab 4X4 TRD Sport with JBL
    Redline Tuning hood struts, tinted windows, FX-R HID projector retrofit headlights, AMP power steps, Morimoto XB projector LED foglights, LED bed lights
    Just put my order in. Thanks OP!
  10. Apr 27, 2016 at 8:03 AM
    Daxdagr8t
    Socal
    07 prerunner
    None
    Amazon has this for 5 for $25 too
  11. Apr 27, 2016 at 8:22 AM
    TacoYes
    Do the ones on Amazon include the drain plug gasket? This is worth another at least $5, which makes this even a better deal.
    BizzyB726 likes this.
  12. Apr 20, 2017 at 1:23 AM
    Iron Ikaika
    Iron Ikaika Well-Known Member
    Jay
    Keolu Hills
    '07 DCSB Sport
    Stock, for now.
    Correct. D3 is for the 4L.
  13. Apr 20, 2017 at 8:30 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2019 TRD Pro
    Think you did the math with only one rotor. There's no way to only pay for 70 for pads and two rotors. Plus they have 20% off now.
