General Fabrication
Discussion in 'Long Travel Suspension' started by linked2002, Aug 19, 2011.
  1. Oct 21, 2011 at 4:10 PM
    #181
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    So I've been reading up on the HF Kinker (the air jack powered one). It seems that if you use 1 5/8'' tubing in the 1.5'' pipe die, you can get good results.
    Thoughts?
  2. Oct 21, 2011 at 4:37 PM
    #182
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    The kinker sucks and is a pain in the ass to use. Buy a real bender or make your own like I did and save yourself
  3. Oct 21, 2011 at 4:46 PM
    #183
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    how did you make your own tube bender?...
  4. Oct 21, 2011 at 7:28 PM
    #184
    cummins6speed
  5. Oct 21, 2011 at 8:21 PM
    #185
    Mxpatriot
  6. Oct 21, 2011 at 8:46 PM
    #186
    cummins6speed
    Depends on what you get. It uses pro tools dies. I think I paid $240 or so for my 1.75x6x240º
  7. Oct 22, 2011 at 10:53 AM
    #187
    linked2002
    linked2002 [OP] Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    ^^^ he has the right idea. Fuck the kinker . You will spend more time trying to get it to work than it's worth. Either make yours or suck it up and buy one on c-list man. The deals are out there.
  8. Oct 24, 2011 at 2:17 AM
    #188
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    How long are the springs? The 52.5 rule only applies to 62inch springs with 12" shackles.....
  9. Oct 24, 2011 at 12:48 PM
    #189
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Anyone want to edumacate me on oxy fuel torch cutting?
  10. Oct 24, 2011 at 12:52 PM
    #190
    linked2002
    san diego
    what about it?
    its dirty.... get a plasma.... its not quite as dirty. :D
  11. Oct 24, 2011 at 12:55 PM
    #191
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    LOL x2 the only way to cut unless your cutting like 2.5" plate then the oxy would be my choice.
  12. Oct 24, 2011 at 12:56 PM
    #192
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Also expensive.. word on the street is you can pick up a cutting torch setup for <200 on CL... and because i want to cut stuff to be cool.
  13. Oct 24, 2011 at 1:11 PM
    #193
    linked2002
    san diego
    i would really suggest investing in a jig saw w/ metal blades, a small circular skil saw, and a saw-z-all before i suggest a oxy set up.. if you cant get it with one of those saws and a grinder, something is wrong. and those saws will cut way cleaner wasting less material. may take a little longer, but your pocket will thank you for not wasting as much.
  14. Oct 24, 2011 at 1:21 PM
    #194
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Good thinking!! Hadn't thought of a jig saw... Right now Im cutting things with a chop saw and an angle grinder.
  15. Oct 24, 2011 at 1:26 PM
    #195
    linked2002
    san diego
    hahaha shit im still cutting shit that way hahaha. i still dont have a damn jig saw. i should prolly take my own effin advice! hahaha
  16. Oct 24, 2011 at 1:26 PM
    #196
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  17. Oct 24, 2011 at 1:29 PM
    #197
    linked2002
    san diego
    never used that saw but good choice on a cold cut blade! i need to invest in one of those as well hahaha
  18. Oct 24, 2011 at 1:31 PM
    #198
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Same here. Harbor freight grinder FTW!
  19. Oct 24, 2011 at 1:35 PM
    #199
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Thats the size I have, 14 inch abrasive cut off... whats this cold cut blade? advantages?
  20. Oct 24, 2011 at 1:39 PM
    #200
    mjp2
    NJ
    The metal doesn't heat up and can be handled immediately. No bluing of the metal at the cut site either, but that's doesn't exactly matter if it's getting welded later anyway.
    Should also be a bit cleaner as there's no abrasive particles coming off the blade during the cut.
