General Fabrication
Discussion in 'Long Travel Suspension' started by linked2002, Aug 19, 2011.
  1. Sep 30, 2016 at 8:58 PM
    #2181
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Awesome, will do! So don't try to power through the cuts, slow and steady wins the race.
    malburg114 likes this.
  2. Sep 30, 2016 at 9:00 PM
    #2182
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Very much so. When you don't let the saw just chew through, the steel heats up which hardens it, making the cut tougher, wearing out the saw faster and often the heat will oval the hole saw too. We use the same notcher and a DeWalt drill.
    stumbles likes this.
  3. Sep 30, 2016 at 9:02 PM
    #2183
    VolcomTacoma
    Jeff
    NorCal
    Great! Thanks for the info! Have alot of ideas in my head for some self fab stuff on the truck that could be interesting :)
    Mobtown Offroad likes this.
  4. Sep 30, 2016 at 9:02 PM
    #2184
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    You're going to have loads of fun with the items you got! So much things to be made.
  5. Sep 30, 2016 at 9:03 PM
    #2185
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i cant find any pics of the one i made for my old work, but i want to say i had under 200 bucks making my own setup. some angle iron, and i used some scrap 2" tubing. went to ebay to find the cheapest bearings i could find (happen to find some 1.75 bearings that worked perfect) and some time.
  6. Sep 30, 2016 at 9:05 PM
    #2186
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Oh and when coping the steel tubing, let's say 1-3/4" od, don't cope the piece that'll be perpendicular dead center as in coping it to .875". Step back off that by .25" to .375" so you have some wall thickness to weld to. If you take it to the point then you'll just burn away material and have a weaker piece. Make sense?
  7. Sep 30, 2016 at 9:05 PM
    #2187
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I've tossed around the idea of making one. I've seen lots do it and it is cheaper. Just thought if I could find one cheap enough if grab it.
  8. Sep 30, 2016 at 9:19 PM
    #2188
    VolcomTacoma
    Jeff
    NorCal
    Nope lol, you lost me, I'm coming from a mechanic/operator background with very little fabrication work under my belt, but after watching a few other guys build stuff I decided I was tired of paying for it and I want to learn how to do it myself! If after a few years I still suck balls at it and all my stuff looks like the tin man took a shit, then maybe I'll rethink it lol.
    The little I understood about that was basically don't cut the notch at such a steep angle that it will leave thin metal on one side that will just get burnt through
  9. Oct 1, 2016 at 6:00 AM
    #2189
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    We built our tube rests for the band saw I just used C channel and conver rollers I bought on McMaster Carr they are 10 foot and you can roll 500+ lbs of tube on it with one hand.
    I did cheat and toss the channel on the plasma to cut evenly spaced hexagonal holes that they required.
  10. Oct 1, 2016 at 6:07 AM
    #2190
    JLee
    Jerry
    Benicia, CA
    Is what he's saying is when making a cope you dont go to the center of the hole saw. You cut the notch a little less only cutting about 80% of the tubes wall on round tube.
    Think of a square tube notch you want to move the hole saw in just enough to cut the two side walls and not touch the bottom and top wall make sense?
  11. Oct 1, 2016 at 7:44 AM
    #2191
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    That is true with all drill bits really, a bit of actual cutting fluid and the right speed gets you there a lot faster and cleaner. I like real cutting fluid vs WD because it handles higher temps and is made to cling to the surface and not just run off or burn off.
    Mobtown Offroad and malburg114 like this.
  12. Oct 1, 2016 at 1:30 PM
    #2192
    VolcomTacoma
    Jeff
    NorCal
    I think I get it. So when notching the end of a tube dont use the full bit, only use enough to cut the notch but the tube doesnt go even halfway through the bit
    malburg114 and Mobtown Offroad like this.
  13. Oct 1, 2016 at 1:31 PM
    #2193
    VolcomTacoma
    Jeff
    NorCal
    True, very true. I was spoiled when I worked at that machine shop in Sac, they had a giant drill press with 100s of bits and cutting fluid and cooling water spigots to blast the stuff you were cutting built in to the press. The thing was the size of a car, but dam it could make a hole.
  14. Oct 1, 2016 at 1:42 PM
    #2194
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    You got it!
  15. Oct 1, 2016 at 1:44 PM
    #2195
    VolcomTacoma
    Jeff
    NorCal
    Makes sense! Thanks guys! First project is a cart for my welder (Miller 211)! Then we'll see how that turns put and if I have the skills and knowledge to tackle some truck stuff :)
  16. Oct 1, 2016 at 2:03 PM
    #2196
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Just play with settings on scrap and practice technique. I always recommend practicing on thin stuff, if you can weld thin without blowing thru and warping then you'll be a damn professional on thick stuff.
    Dalandser likes this.
  17. Oct 1, 2016 at 3:16 PM
    #2197
    VolcomTacoma
    Jeff
    NorCal
    Yeah I still need to stop by @JLee 's shop and raid his trash/scrap pile for some practice stuff
  18. Dec 2, 2016 at 7:39 PM
    #2198
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    Anyone use bend tech? Considering getting the pro version since im caging/linking my truck in a few weeks
  19. Dec 2, 2016 at 7:40 PM
    #2199
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I use it daily. It's the bees knees.
  20. Dec 2, 2016 at 7:58 PM
    #2200
    dirt addiction
    Flagstaff
    Pretty easy to pick up?
