General Fabrication
Discussion in 'Long Travel Suspension' started by linked2002, Aug 19, 2011.
  1. Feb 19, 2022 at 7:46 PM
    #2481
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    From my rough measurements you wouldn't have to change the cross member to fit the 8" diff. The biggest issue is it's 1.5" wider per side than ours. So compensating for that gets complicated.
    Still wish brian at FROR Had released his kit for that. Would have sold a lot I bet.
    Dalandser[QUOTED] likes this.
  2. Feb 19, 2022 at 11:42 PM
    #2482
    Happysmiley
    Happysmiley Well-Known Member
    Fabien
    Northern NV
    89 pickup 87 pickup 2016 4runner
    Gotta check out a 1st gen again , forgot how the tabs are more on the edges of the crossmember
    Could maybe do it with tube subframe built from crossmember to crossmember and mount tabs off the tube if its out away from the crossmembe, then gusset and plate it in
    I hear you on not an ideal location or timeframe to get crazy with the mounts
    Closed my photobucket account so old threads prob have no pics but downloaded them all on my phone
    Old 4runner I didnt push the mounts forward but wish i had. Might on my DD when I get it going or ill just build it into the lower arm geometry
    Just an idea if you cant get the alignment you want with your stock mount location but sounds like you will be able to
    Can always change things up down the line
    Dalandser likes this.
  3. Feb 20, 2022 at 7:00 AM
    #2483
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I traced your diagram and this is what I came up with. I used 1/4" for the thickness. Is this what the part should look like?
    Happysmiley and Dalandser like this.
  4. Feb 20, 2022 at 7:03 AM
    #2484
    koditten
    Kirk
    Central Michigan
    https://a360.co/3H28PBV
    I've never shared a file before, F360 says I can share by posting the above link in a browser and you don't need Fusion 360 installed. You are welcome to try. I make no promises.
  5. Mar 15, 2022 at 7:56 AM
    #2485
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    It looks like you're trying to make the TacoTabs that Poly Performance sells. I love them on my truck. I like that there is overall 3 settings with each tab, something to consider. I need the oval inserts in the center and offset (actually just the offset) to "plug" the hole in the factory mount to have the bushing flush. @koditten or @Happysmiley can you cut those?
  6. Mar 15, 2022 at 9:55 AM
    #2486
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    VIA your link here is the DXF which is what will be used to cut the flat part.
  7. Mar 17, 2022 at 9:50 PM
    #2487
    Happysmiley
    Fabien
    Northern NV
    I hand drilled, cut, and shaped the filler pieces i made for my 4runner
    If i ever step up and get a plasma table it would prob be something I'd make
  8. Mar 18, 2022 at 1:13 AM
    #2488
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I appreciate it. Unfortunately I wasn’t able to get the caster I wanted unless I was running all out on the rear cams and all in on the front and I just didn’t feel like I wanted to commit to locking in the mounts, never having driven this truck besides once turning it around a few years ago to work on the back. @Happysmiley convinced me to hold off on it until there’s more time to assess how I feel with different caster settings and maybe redoing the lower mounts if I want much more caster.
    I did go ahead and download the app but it wanted me to sign in for some reason to view the file. Again I appreciate your help! One of these days I’d like to get a cad program to design a bunch of stuff. Thank you.
    Yeah basically like a weld on cam bolt eliminator was the part I was designing. As I said above I decided not to commit to welding something I wasn’t 100% on before driving the thing. Instead I went with another company making cam eliminators and made filler pieces ala @Happysmiley after he explained how they give the bushing sleeves more surface area to mate to. These I made out of 1/4” flat bar with a hole saw and an angle grinder. They’re different because 1st gens use 3/4” hardware that takes up the whole cam slot. Idk maybe his were custom for different bushing sleeves and narrower hardware.
    Now I’m rebuilding the uca mounts from unsuccessfully going from one long bolt to two shorter ones. Lol the snowball never seems to end. Haha
    koditten[QUOTED] likes this.
  9. Mar 27, 2022 at 5:23 PM
    #2489
    xx3xil3xx
    xx3xil3xx Well-Known Member
    ESCONDIDO/SAN DIEGO, CA
    06 runner
    Quick question...for guys that built their bed cage, what tubing size did you guys use and does it have to be dom? I have an 06 and installing a 2.5x16 bypasses...
  10. Mar 27, 2022 at 5:32 PM
    #2490
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I would think .120 would be ideal for strength but DOM wouldn't be necessary. .120 mild steel would offer good strength but a better price.
  11. Mar 27, 2022 at 9:05 PM
    #2491
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    1.75 is nice and I think @desertjunkie760 meant to say hot rolled tube is ok - DOM and HREW are mild steel, HREW won't kill your bank account.
    desertjunkie760 and Shmellmopwho like this.
  12. Mar 31, 2022 at 9:16 AM
    #2492
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Hrew is fine, definitely do 1.75 .120 wall though.
  13. Apr 2, 2022 at 11:58 AM
    #2493
    William H. Bonney
    William H. Bonney Well-Known Member
    2016 TRDOR
    I work with HREW .120 and .40 for sprinkler work. A lot of times walking into warehouses you see areas where forklifts smash into the sprinkler pipe, it’s surprisingly strong. Even at .120 it just bends never seen it crack.
  14. Apr 2, 2022 at 12:10 PM
    #2494
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Okay but like...
    How do you alignment?
  15. Apr 2, 2022 at 2:19 PM
    #2495
    Happysmiley
    Fabien
    Northern NV
    Align using the heims on the upper arm
  16. Apr 4, 2022 at 1:54 PM
    #2496
    desertjunkie760
    Shane
    Check My Sig.
    You are correct. Thank you for catching that. :hattip:
  17. May 10, 2022 at 8:35 PM
    #2497
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    I suck at mig but thought I would post a few pics of some fab not bought shit. Mounts and a high steer. Both pretty simple. Drilling matching holes is the hardest thing.
    Steering gear has been a bitch.
    811997FD-0DBA-430D-ADFF-B73ED6EB647C.jpg 25B60F68-2126-4E76-82C8-63D1FFCD3DA3.jpg 1098B3EA-DB3F-4D20-BC5C-5DE07DEC5F4A.jpg 8D6E3F1F-E04F-4C89-9DF6-93D21F213DA4.jpg
    jubei, malburg114 and T.Barn like this.
  18. May 10, 2022 at 10:10 PM
    #2498
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Not worried about vibes with solid mounting the motor?
    tacoma16 likes this.
  19. May 17, 2022 at 5:32 PM
    #2499
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Few things left to finish up
  20. Aug 24, 2022 at 4:37 PM
    #2500
    volcomstone1223
    volcomstone1223 Well-Known Member
    Lake Havasu City
    05 Taco LSupreme
    Solo DMZ
    I did my motor mounts pretty similar to yours I just made them fully removable.
