General Fabrication
Discussion in 'Long Travel Suspension' started by linked2002, Aug 19, 2011.
  1. Jan 9, 2023 at 1:30 PM
    #2561
    Tacogeorge17
    Tacogeorge17 Well-Known Member
    George
    Socal
    2017 black Tacoma TRD OR manual
    So far I can say that @Dirt King Fab has hands down some of the best customer service I have experienced since getting into trucks. All the questions I’ve had were always answered and answered with the upmost professionalism! So I know tackling the install myself I can go to them for all the necessary info, which I will need to lol.
  2. Jan 13, 2023 at 8:14 PM
    #2562
    erok81
    erok81 Well-Known Member
    Imposter
    So first off, I know this isn’t a great question, so please don’t kill me for asking. :D
    I’m really low on shielding gas for my mig and conveniently under a tight time line to get my truck done. This weekend I have to get two perches welded on. Let’s say I run of gas…
    I only really have two options. Go buy some flux core wire (I haven’t used this in a very long time) or try using nitrogen for shielding gas.
    Google failed me since most things I read were people wanting to use it due to price or trying to improve welding. Nothing just using it in a pinch.
    What’s the word? Think it’s doable or am I screwed.
  3. Jan 14, 2023 at 2:54 PM
    #2563
    Pyrotech
    Pyrotech Well-Known Member
    I would be worried about the nitrogen making the steel brittle and prone to cracking.
    Search Nitrogen embrittlement on google
    BMiller421 likes this.
  4. Jan 14, 2023 at 3:03 PM
    #2564
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I know you can use CO2 for shielding gas but not sure if nitrogen will work.
  5. Jan 14, 2023 at 3:16 PM
    #2565
    erok81
    Imposter
    Yeah that’s one result I found. Mixed with other results it makes the weld stronger unless you are using really high amperage/voltage. Didn’t go too much farther on it.
    Well good news/bad news. I can’t get to the welding part this weekend anyway. I had to cut off every piece of hardware for the leaf springs. So no reinstalling until I can get more. :rain:
  6. Jan 14, 2023 at 4:23 PM
    #2566
    desertjunkie760
    Shane
    Check My Sig.
    Why’d you have to do that?
  7. Jan 14, 2023 at 4:25 PM
    #2567
    erok81
    Imposter
    All of them were seized in the sleeves. All I have is a MAP torch and a 2.5# mini sledge. Neither of which worked.
  8. Jan 14, 2023 at 9:34 PM
    #2568
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    thats always a bummer.
    erok81[QUOTED] likes this.
  9. Jan 14, 2023 at 9:45 PM
    #2569
    erok81
    Imposter
    Yep. Sucks too because I have a deadline to get all of this done. So the three day weekend would have been nice.
    But I’m basically done now because no one local sells the sleeves and I’m not sure on the bolts either.
  10. Mar 8, 2023 at 8:43 PM
    #2570
    erok81
    Imposter
    So first off since I just saw my old posts…remember my shielding gas problem? Well my main pressure gauge is broken so I can only tell airflow by the actually nozzle flow gauge ir hearing it. Somehow I had closed the nozzle flow valve. Noticed it shortly after the post. I’ve gone through probably another half spool of wire and still haven’t ran out of gas. :burp: :facepalm:
    Now for my question. How many of you have successfully built your rigs with a 110 mig? Up to this point I’ve built multiple rigs using 110 and have yet to break a weld. My younger self didn’t care, but now that I’m older I’m a bit nervous to be gluing structural parts together with my 110.
    My future plans are JD lower mount kit, rear links, maybe taller coil buckets for the front, etc. All of those failed welds = disaster.
    I’m a loser forever renter so anything over 110 is never going to happen.
    What’s the word?
  11. Mar 8, 2023 at 9:01 PM
    #2571
    desertjunkie760
    Shane
    Check My Sig.
    kind of a loaded question. You have already successfully built rigs with 110. I would personally progress with caution but it really depends on the thickness of metal you’re trying to weld. The JD relocation is damn near 1/4” thick in itself.
  12. Mar 8, 2023 at 9:59 PM
    #2572
    erok81
    Imposter
    Well current one is really just welding perches and shock mounts. Lots of 1/4” which I usually preheat first.
    The other main one was a competition rock crawler (back before there were buggies) where is designed my own four link with 1/4 elliptic springs. Nothing broke but I can’t say if my younger self gave me that jeep if I’d actually feel comfortable driving it at freeway speeds. :anonymous:
    Plus I feel like what we build out trucks for is way more harsh than rock crawling (maybe not driveline and body panels though). Not counting the nut jobs that drive up hills at 80mph and 110% throttle. :rofl:
  13. Jun 8, 2023 at 4:38 PM
    #2573
    clg
    clg Well-Known Member
    2017 Off-road
    By chance does anyone have dimensions for LCA mounts of a 3rd gen? I'm shredding bushings like a mofo in my 3rd gen, and I think my tabs may be bent. Figured ya'll fab'ers may have either access to what things should be, or a clean setup that's easy to measure.
    Thanks!
  14. Jun 9, 2023 at 6:28 AM
    #2574
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Not exactly what you are asking, but I will share my experience.
    Years ago, a motorcycle slid into me (wet roads - he was OK). He punctured my left front tire, bent the wheel, bent the spindle, and slid along my slider. I was going about 20 MPH at the time, and on the other side of me was a long drop off. Back to the truck...
    Replaced the spindle, wheel and tire, and aligned it to spec. But, when I turned, the tire rubbed on the rear of the inner fender - never did that before. Further investigation revealed the mounting tabs for the LCA were bent to the rear - sort of a "Z" bend, since the tabs were still parallel to each other. The center point moved rearward. But it was still in "spec".
    To fix this, I used a bottle jack against the crossmember. I straightened the tabs, put the suspension together, and got it aligned. Now, the tire does not rub. Again, in "spec". (Same shop - and I do trust them to do good work.)
    Point of all this is, I don't know that "specs" exist. I suggest you measure several trucks. Once you see how they are, your issue will hopefully become obvious.
  15. Jun 9, 2023 at 9:35 AM
    #2575
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Its best to have both camber/castor tabs "even", so you aren't cocking the Lca (say you have the castor cam maxed outwards, and camber cam maxed out inwards, thatd put twist on the bushings).
  16. Jun 26, 2023 at 10:40 AM
    #2576
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
  17. Jun 26, 2023 at 12:22 PM
    #2577
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    I have a cheaper version of that because I don't use it but once a year maybe. The only issue I had was the hole in the die where the screw is to mount to the bender left dimples in the tube. I was bending 1.75x0.120 mild steel.
  18. Jun 26, 2023 at 12:25 PM
    #2578
    Kwikvette
    Fresno County
    4 run, 2 don't
    Buying into JD2, you're really doing it for the quality of their dies.
    Roguefab does some weird shit to tube when you bend it, causing it to stretch in a way that it really pushes the diameter of your tube quite a bit.
    I was about to order from JD Squared but want to do so via phone. Had some questions to ask but their communication is horrible.
    Everyone's been happy with their products (that I've talked to), but expressed the same lack of comms and long wait times.
    With that said, I'm still going JD Squared regardless.
  19. Jun 27, 2023 at 9:05 AM
    #2579
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Thanks for the info, I am probably going to go with the one I linked cause as of now its just for personal use. Maybe if I can justify it financially(it'll pay for itself) I'll upgrade in the future.
  20. Jun 27, 2023 at 9:11 AM
    #2580
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
