General Fabrication
Discussion in 'Long Travel Suspension' started by linked2002, Aug 19, 2011.
  1. Nov 6, 2013 at 10:39 AM
    #1381
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    First thing it's $300 dollars that tells you right there it's crap. A good TIG alone will be over $2,000 and that's starting.
    Second I would never buy a plasma/welder machine only they tend to have more problems then stand alone machines. Third I wouldn't try and ARC weld for fabricating parts MIG is best for that.
    I have learned in this business you get what you pay for and that's not even hobby grade in my book.
    You can buy a cheap machine if you like but you will be regretting it later down the road.
  2. Nov 6, 2013 at 10:59 AM
    #1382
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Good point there. Makes sense.
    Thanks for the expansion on the info. In response, Just because I said I can GET it for $300, doesn't mean that is the price. The average price for it is between $450 and $500. As for a good TIG running $2000, remember, I am buying for doing SMALL projects. I really was not even looking too much at the TIG part, but that it is an arc welder, and a plasma cutter. I do see the point in a combo machine not necessarily being the best option. Yes, I do realize that MIG is the best for fabrication, but back when I was learning to weld, nobody really did MIG welding. It was all arc, or brazing for brass and such.
    I do appreciate the information though. I am still working on seeing if my current MIG welder is up to the task. I have a Clark 130EN that I have used for the past 6 or so years, and it has worked great for some of the light work I have done. Stepping into the world of fabrication of tubing and such, I am not sure if it is up to the task or not. I saw that one I linked where I was able to pick it up for just $300, so I was curious.
  3. Nov 6, 2013 at 11:15 AM
    #1383
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 4x4> 03 SR5 4x4 total> 14 Crewmax TRD
    Had tons on the old Taco's.... new Tundra is pretty stock
    As with Jerry, I would personally RUN away from that machine. Just looking at it it looks terribly made, and the price is a further giveaway there too. I doubt they'd warranty any issues.... if you could even get ahold of the company.
    Even for small around the home projects I would expect to drop around $800 on a quality welder (check out the ThermalArc 181i) and easily $1500-2000 for a quality new plasma cutter (or around 2/3 that for a used one).
    Cheaping out on welders/plasma cutters is a bad idea IMO. You definitely get what you pay for, and you'll pay the difference in headaches with a cheap machine. I would rather have a machine that I know I can easily get support/parts for if necessary, and that I know will work when I need it. I'd also like peace of mind that the machine I bought is actually properly welding my project rather than looking good on the surface and having no penetration causing part failure later on. I've seen guys with cheap Harbor freight welders lay a bead that looks decently sound, but the bracket/gusset snap off with absolutely zero penetration into the base metal. :eek:
  4. Nov 6, 2013 at 11:35 AM
    #1384
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Landry
    North Carolina :/
    2015 TRD Pro Inferno 6spd SUPERCHARGED! DCSB
    Wheelers 3/4 isolator, TRD Supercharger, Weathertech window visor, weathertech digital floor liners, Rigid 30 E series, rear spring mess. Awesome seat covers.
    My gramps has a Lincoln sp170t I belive. Been awhile since I looked and I have welded lots of stuff with it. For the price a Lincoln 170 or 180 like the 180 dual are great options in my opinion.
    The welder I prefer at home is my dad's hobart 240 "ironman" I believe its called and it is a bigger machine than the Lincoln s and also has a much better duty cycle and adjustability. He got his used for $500 and its never let him down. I have a hobart 140 flux core that works but I plan to buy a larger machine when I have money and space available.
  5. Nov 6, 2013 at 12:04 PM
    #1385
    BamaToy1997
    Bill
    Navarre, FL
    Interesting to know. I guess that I wrongly assumed that all welders that were say 130A would have the same penetration. Now THAT is a lot of information there. Since I am looking at getting your DIY bumper kit, do you think my Clarke will do that at a moderate duty cycle?
  6. Nov 6, 2013 at 12:27 PM
    #1386
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    I have been using my buddies Eastwood 175 210v and had no issues with it. Granted im not about to start making stuff for a living..
  7. Nov 6, 2013 at 12:35 PM
    #1387
    BamaToy1997
    Bill
    Navarre, FL
    You hush! It's your damn fault I have started looking into this stuff in the first place! :D :p:p:p
  8. Nov 6, 2013 at 12:37 PM
    #1388
    Blackdawg
    Monte
    Wyoming/St. Louis
    hahahaha hey...you'll thank me later :D haha
    but idk how much the eastwood runs..but its been a great hobby welder IMO..my dad and i use it a lot as does the owner..and it never has caused use any issues at all..
  9. Nov 6, 2013 at 5:40 PM
    #1389
    JLee
    Jerry
    Bay Area NorCal
    Lets get back on topic :D
    Spring back on 1.75" x.120 HREW what are you guys going too.
    We have been doing a lot of tested with the new bender and are coming up with 10.3 degrees on this bundle of tube. I have my bender set to 90.0 degrees with a spring back of 10.3 and I get a dead nuts 90 degree bend give or take .1 degree over 10 bends. Yes I'm down to the 10th of a degree :D I know most of you guys can't get it down that low so I think 10 is a good starting point.
    That's saying you guys are calculating for spring back :p
    I'll have some more numbers on other standard sizes once we toss them on the bender. I'm also going to mess with bending speeds to see if that will provide a different number. Were bending on speed 6 right now that's 180 degrees in 9 seconds.
  10. Nov 6, 2013 at 6:08 PM
    #1390
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
  11. Nov 6, 2013 at 6:49 PM
    #1391
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Yes. You're good
  12. Nov 6, 2013 at 7:10 PM
    #1392
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    Just as long as it's the same brand. Hi-lift, torin, big red, harbor freight, etc. All vary by just the smallest amount.
  13. Nov 6, 2013 at 7:13 PM
    #1393
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Fort Collins, Colorado
    bone stock / unmolested 04 2.7L
  14. Nov 6, 2013 at 7:24 PM
    #1394
    Boone
    Boone, NC
    Airbags deployed
  15. Nov 6, 2013 at 7:31 PM
    #1395
    Boone
    Boone, NC
    Airbags deployed
  16. Nov 6, 2013 at 9:19 PM
    #1396
    45acp
    Jonathan
    Yeah. I talked to a guy at the company and he said they've been making the hi-lift bars (both 48" and 60") on two different machines since like the 60's. They are slightly different and it shows. SO... the answer is it may or may not fit. A 50/50 chance? :notsure:
  17. Nov 6, 2013 at 10:30 PM
    #1397
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    3" lift, custom rims, snug top shell, shrockworks bumper, warn winch.
    But if the lifting mechanism works on both, it's a non issue. At least I think it would be.
  18. Nov 6, 2013 at 10:39 PM
    #1398
    45acp
    Jonathan
    In regards to mounting, it would be. Weld the mounting bolts to the rack for one hi-lift, may not fit another. That's how I found out.
  19. Nov 7, 2013 at 5:20 AM
    #1399
    Boone
    Boone, NC
    Airbags deployed
    Good to know. I'll correct my reply to the next person that asks me that. Thanks for the insight.
  20. Nov 7, 2013 at 8:07 PM
    #1400
    redrider58
    redrider58 KG7TBQ
    Tucson,AZ & Durango,CO
    Silver DCLB 4x4
    Mods: Not enough
    I read through as many pages as I could and I could get my question answered.
    What diameter and thickness of tubing and what type of steel are you guys using for racks, bumpers, sliders, bed cages?
