General Fabrication
Discussion in 'Long Travel Suspension' started by linked2002, Aug 19, 2011.
  1. Oct 8, 2014 at 5:27 AM
    #1561
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Walnut shells are usually for AL or other soft metals. I only use Black Beauty. Plentiful around here, cheap, and the toughest media you can get. Its crushed steel slag from the mills. :D
  2. Oct 8, 2014 at 7:26 AM
    #1562
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I'm new to this whole steel fabrication thing so my knowledge of the specialty tools out there is limited. I purchased several right angle magnets to help with fixturing, but found the cheap harbor freight magnets pretty inadequate. I did some searching today and found strong hand and magswitch on/off magnets. I have two of the 165 magswitch units and two of the medium duty strong hand magnets on the way. Can't wait to try them out on the bed build.
    I'm sure most of you know about these, but they're new to me. So what other cool tools are a out there that are a must have?
  3. Oct 8, 2014 at 7:39 AM
    #1563
    MojaveMadman
    MojaveMadman Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Probably late to this one... I have a Pro-Tools 105HD and love it. I landed on this over the JD2 because the dies are cheaper. I have used all 3 big brands (PT, JD, JMR) and IMO for a home fabricator they all work exactly the same... Trick-tools.com has great prices and shipping. I got my bender and all my dies from them.
  4. Oct 8, 2014 at 6:31 PM
    #1564
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I have the cube ones and we use them just about every day. You can't really go wrong with strong hand tools when it comes to clamps. I have their build pro Max table and it's amazing!!
  5. Oct 8, 2014 at 6:32 PM
    #1565
    JLee
    Jerry
    Grass valley CA
    And the shitty blaster your using :eek:
  6. Oct 18, 2014 at 1:56 AM
    #1566
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    sup guys! I want to learn how to weld so I want to buy a welder and teach myself. Which welder do you guys recommend? Ill ask for help first to someone that know how to use a welder to get me started.
  7. Oct 18, 2014 at 3:25 AM
    #1567
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    This is the one I'm using.....Well worth what I spent for everything I've been doing.
    http://store.cyberweld.com/twfa14miwew1.html
  8. Oct 18, 2014 at 2:50 PM
    #1568
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Get a used Lincoln flux core welder or whatever brand off cl for a 100. You can sell it when you want to upgrade to better mig.
  9. Oct 18, 2014 at 8:40 PM
    #1569
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Fuqu the flux core!
    Get any welder that allows you to use cover gas. Learning how to weld is so much easier. Its safer too. The bb's that flux core welding make, shoot out a long ways from where you are welding from and they stay red hot! The fire hazard alone is enough to keep anyone from using flux core.
    About the only instance I would recommend flux core, would be if you had to weld outside in a heavy wind. It does have other advantages, but not enough for me consider it worthwhile to even meantion.
  10. Oct 18, 2014 at 8:53 PM
    #1570
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
  11. Oct 18, 2014 at 9:04 PM
    #1571
    koditten
    Kirk
    Central Michigan
    You can't sub'd without bringing something to the table. It's just impolite.
    What do you want to here about? Lots of collective knowledge in this thread, give us a chance to run off at the mouth:)
    KO
  12. Oct 18, 2014 at 9:14 PM
    #1572
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Just remember you can use the flux core outside in the breeze where the gas is gonna get blown away and produce a shitty weld.
  13. Oct 18, 2014 at 10:46 PM
    #1573
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Made this bumper last month. All I had was a grinder and a small pipe bender. Used my buddy's little Lincoln Mig. I thought it came out okay for my first one. Wish I had a plasma cutter!!!! Made the bedrack and the sliders too but don't really have an pics of those.
  14. Oct 19, 2014 at 9:43 AM
    #1574
    MadTaco461
    CA
    Kinda stock
    I just said flux is good to learn on. Don't make anything structural for a truck like suspension parts. If you can lay down good flux, mig is a breeze. 100 bucks for a used welder is what I learned on. A few years later I dropped a 1000 on a nice 180amp mig. There is a world of a difference between the 2
  15. Oct 21, 2014 at 12:30 PM
    #1575
    JLee
    Jerry
    Grass valley CA
    i figured Id post this here as well.
    I have a TN 300 in the shop that I'm considering on selling the price is $2000. I'm upgrading to the TN 800 end mill notcher soon. It's about 6 months old and works great we just want to fine tune the notch for SS Tig welding and an end mill notcher is what we need. If your doing a lot of notches and don't want to drop 8K+ on a end mill notcher this thing is bad ass. And no more near broken arms! all you guys with drill notchers know what I'm talking about :D
    Local pickup in the Bay area would be best as this thing weighs in at about 150lbs I can ship it freight to just about anywhere in the us for about $100 bucks but local pick up would be best. My shop is in Benicia
    Here is a video of it in action
    http://youtu.be/sKU-zGF4d5I
  16. Oct 21, 2014 at 12:40 PM
    #1576
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Sounds l like you're doing judging from all the upgrades, congrats!
  17. Oct 21, 2014 at 3:17 PM
    #1577
    JLee
    Jerry
    Grass valley CA
    Yeah we do alright :cool:
  18. Oct 21, 2014 at 4:19 PM
    #1578
    nagorb
    Alabama
    2001 dbl cab 4x4
    Haha awesome!
  19. Oct 21, 2014 at 4:24 PM
    #1579
    GEARAHOLIC
    GEARAHOLIC Well-Known Member
    KELLEN
    PASO ROBLES, CA
    07 Black on Black BEAST
  20. Oct 22, 2014 at 6:44 AM
    #1580
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    I have used a few kinds of notchers and always find myself going back to the chop saw method. Used the drill press ones, they take way too long and you go through hole saws fast. Used the giant belt sander ones, they are so noisy and you go through belts fast when doing big projects. I even used a nibbler version. All those things are great if you are doing a large TIG project, or you are repeating a notch 100 times, or you have a huge budget. But man I have just become so proficient with with chop saw and grinder I can put 5 tubes in a roll cage in the same time it takes someone to notch one tube on the dang drill press. Plus the cost of a good chop saw is still far less than anything else. I learned from old school guys and I guess that is one thing that stuck with me.
