General Fabrication
Discussion in 'Long Travel Suspension' started by linked2002, Aug 19, 2011.
  1. Sep 22, 2011 at 2:27 PM
    #141
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I paid 250 for mine with 2 dies but it only does 90s on a 7"clr which is a pain
  2. Sep 22, 2011 at 2:28 PM
    #142
    linked2002
    linked2002 [OP] Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    oh thats a bummer man. still not a bad deal though. definitely better than nothing.
  3. Sep 22, 2011 at 2:32 PM
    #143
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Oh yeah that for sure plus it can handle 1.75" 120 wall DOM so that's all I really need
  4. Sep 22, 2011 at 2:38 PM
    #144
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
  5. Sep 22, 2011 at 2:41 PM
    #145
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
  6. Sep 22, 2011 at 2:48 PM
    #146
    linked2002
    san diego
    just remember... worst they can say is the offer is too low... so lower it is.. more money stays in your pocket...
    i would say 400 plus shipping for just welder.
  7. Sep 22, 2011 at 2:49 PM
    #147
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    I offered $425 no helmet, waiting on response
  8. Sep 22, 2011 at 5:46 PM
    #148
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    Got him down to $525, might keep looking.
    He's local
  9. Sep 30, 2011 at 10:56 AM
    #149
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
  10. Sep 30, 2011 at 11:04 AM
    #150
    linked2002
    san diego
    fuel cell plumbing with stock pickup/level:
    i will update this with pictures as soon as i can get into my garage and into the corner where my cell is to help give you guys a better understanding.
    best way to start is obviously remove the metal lid that protects your plastic bladder inside the can. remove your stock sender from the stock tank. there will be a rubber seal under it that should be close to the form that you will need to cut out of the top of the cell. use that seal to trace the shape of the hole you will need to cut (you can also mark the holes where the screws will need to go through but i dont reccommend it). cut out the major inner hole (make sure it is the inner one... dont trace the outer edges of the seal and cut or you WILL FUCK YOUR CELL UP!).
    you should be able to maneuver the pickup into the hole you just cut now.... once you have it in, now trace the bolt holes through the holes in the metal plate (top of stock sender) and drill out. i had to cut and extend my float as it wouldnt reach the bottom of my tank. you guys will need to figure that out on your own.. also you will need to figure a way to make the fuel pump pick up at the bottom of the cell (mine was about 4 inches from bottom).
    now you will need to figure out on the lid of your can where you will need to cut out the appropriate holes so that when you put the lid on, all plumbing will be coming out of lid without kinks. im hardline plumbing mine back to the stock lines, but there are other ways to go about it as well. any questions feel free to ask and i will assist you as best i can.
    BE SURE TO CLEAN OUT ALL THE PLASTIC FROM THE INSIDE OF YOUR CELL WITH A SHOP VAC.
    EDIT: SEE PICTURES... THERE IS HOW I DID MINE.
  11. Sep 30, 2011 at 11:08 AM
    #151
    97yota4wd
    Eric
    Mesa, AZ
    awesome man thanks so much.
    pics when you can would be awesome.
  12. Sep 30, 2011 at 11:36 AM
    #152
    linked2002
    san diego
    for sure i will try to take some tonight. it is really much easier than you would think and saves tons of coin. remember people... Keep IT Simple Stupid. dont go buying shit unless you know for a fact there isnt a safe/cheaper way to make it happen with what you've already got.
  13. Oct 4, 2011 at 11:29 AM
    #153
    linked2002
    san diego
    fuel cell plumbing post updated with pictures
  14. Oct 4, 2011 at 11:34 AM
    #154
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    This cell has no foam or internal rubber bladder, correct? If it does you run into the joys of getting all that stuff to work with the nut ring that seals the bladder and all that other good stuff. You'll also cut away foam as needed to allow the float to move without interference.
  15. Oct 4, 2011 at 11:35 AM
    #155
    linked2002
    san diego
    no i have a full foam fill in there. it is all placed accordingly so my float can swing freely.
  16. Oct 4, 2011 at 11:39 AM
    #156
    mjp2
    NJ
    Nice! Solid solution, and it's the same one I took on my truck. :thumbsup:
  17. Oct 4, 2011 at 12:10 PM
    #157
    linked2002
    san diego
    hahah that proves a point then... the both of us cant be completely nuts... must work hahaha
  18. Oct 4, 2011 at 2:35 PM
    #158
    97yota4wd
    Eric
    Mesa, AZ
    :popcorn:
    this should be.... interesting.....
    my cell has a plastic bladder.. so you cut them both accordingly, then bolt it down like this.... bolt, outside of fuel cell, plastic bladder, nut. right? i really dont want to mess this up lol
  19. Oct 4, 2011 at 2:39 PM
    #159
    linked2002
    san diego
    lol wait wait.. you guys do know that the lid to my cell isnt on right? that is the pick up drilled directly into the plastic bladder that is filled with foam.
  20. Oct 4, 2011 at 2:42 PM
    #160
    mjp2
    NJ
    Mine has a custom rubber bladder. The stock pump/sending unit is sandwiched in a custom ring built into the access cover that bolts to the internal nut ring.
    The nut ring attached to the internal bladder is what the oval plate bolts to. The rest of the nuts and bolts simply hold the filler and the stock pump to the oval plate.
