General Performance Questions
Discussion in 'Performance and Tuning' started by Performance, Jun 30, 2011.
  1. Jun 30, 2011 at 1:09 PM
    Performance
    Performance [OP] Member
    Zach
    Fredericksburg, VA
    '11 TRD Sport DC LB Super White
    Hey everyone,
    I am really new the Tacoma set up and I have been trying to do some research and way my options as far as after market performance goes. I have pretty much decided that I am going to slowly upgrade my new truck, and stick mostly with TRD parts only because Toyota will warranty them as long as they put them on.
    My general questions are:
    1. Is the TRD CAI compatible with the supercharger? (I have only owned turbo, and I think that a supercharger is the best option based on how I will be using the vehicle).
    2. Generally a cat back will increase HP numbers so I was thinking TRD, any other advice.
    3. Do headers on these vehicles really produce solid gains?
    Just a little background...I plan on 6 inch lifting and 35's as well as having the ability to pull a boat and run down the road (I-95). Of course this is all over the course of maybe 3 years and saving money :)
    Thanks for any advice you may have
  2. Jun 30, 2011 at 1:13 PM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    If you are going to go with 35" tires you are going to have to re-gear.
    The stock air intake is pretty much a CAI
    I cannot comment on any HP gains from Cat-backs and headers
  3. Jun 30, 2011 at 1:18 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    The new TRD intake is compatible, but I would go with a 1st gen TRD intake or a AFE stage two, same thing but has a scoop at the bottom. Sadly as far as headers go we only have one long tube design header and several short tubes. Long tube is a bolt on and shorties will need to be welded on the two front cats. If you do install long tubes you will need a O2 sim to prevent the CEL to come on. Since your getting boost I would go for the long tubes, better for your EGT's. TRD catback will slightly improve power, but I would go for the 3 in URD catback, again since your going boost. I would highly recommend the URD fuel pump so your pressure doesn't drop off. I would also recommend some tuning but you really don't need to.
  4. Jun 30, 2011 at 1:19 PM
    UMBCrew
    UMBCrew Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    From what ive read yes but the TRD CAI is, according the toyota (of course) the only one. even though im pretty damn sure that the AFE Si 2 Is the exact same CAI. same tube, box, filter, exactly the same like im guessing AFE makes the TRD CAI (for 150$ cheaper)
  5. Jun 30, 2011 at 1:24 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Correct. TRD outsourced AFE to manufacturer their intake. This was the conical design intake. The new one is CARB approved and is a panel filter, the old one wasn't, and I believe K&N is the new manufacture for TRD or so I've heard.
  6. Jun 30, 2011 at 1:26 PM
    Performance
    Zach
    Fredericksburg, VA
    With the headers you are referring to the Thorley header...correct?
  7. Jun 30, 2011 at 1:27 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    yes sir. I have them, but I'm fabbing up my own at the moment. I got them so I could run the hottest tune on my EMS (no front cats).
  8. Jun 30, 2011 at 1:31 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    good to know thank you.
  9. Jun 30, 2011 at 1:31 PM
    Performance
    Zach
    Fredericksburg, VA
    cool. Thanks for all of the quick responses. I am used to driving an Evo so I didn't really do a whole lot other than simple bolt on's. Since you have them, how much louder do the make the truck? Im not shooting for below any db number or anything I'm just curious.
  10. Jun 30, 2011 at 1:38 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    This is how my truck sounds at the moment.
    http://www.youtube.com/watch?v=rocvh4DNXIQ
    This is with a AFE intake and the long tubes. the pos factory y and catback are still in there. some other 1gr owners say it drones when you have a urd y or any other and a aftermarket catback and add two mufflers or a muffler and resonator combo. To be honest how it sounds is going to be within your own personal preference. Since you had an evo (which one BTW? I like the 8 and 9) noise shouldn't be that much of a deal for you.
  11. Jun 30, 2011 at 1:39 PM
    Performance
    Zach
    Fredericksburg, VA
    I had a WW Evo 9. That sounds awesome too BTW. One other noob question, I have a long bed...doesn't look like URD exhaust will fit?? any other suggestions?
  12. Jun 30, 2011 at 1:46 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    AFE makes one for your cab and bed length but doesn't give a diameter. Could always fab up a custom piece.
  13. Jun 30, 2011 at 1:50 PM
    Performance
    Zach
    Fredericksburg, VA
    ok cool, I really appreciate all of your help.
  14. Jun 30, 2011 at 1:52 PM
    UMBCrew
    Nic
    Central Valley, CA
    Now I Know thanks, always wondered just never asked
  15. Jul 1, 2011 at 12:09 AM
    bcroach78
    bcroach78 Well-Known Member
    TN
    2010 Crew cab TRD L/B S/C
    The OP had a double cab long bed. The URD 3" exhaust is not for DC LB. I went with the AFE exhaust that URD has on their site for my DC LB. Havent installed it yet, but should have it one by mid sept.
  16. Jul 1, 2011 at 12:20 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Ive got the superchager, the trd/afe intake, the URD 3 inch exhaust with a DCLB, and 33s. I tow a #4000 boat and its sluggish but not bad just with 35s and a lot of towing you will want a regear.
  17. Jul 1, 2011 at 8:27 AM
    Performance
    Zach
    Fredericksburg, VA
    Ktmrider: your set up sounds very close to what I want. Did you have to fab the URD exhaust to make it fit the long bed?
  18. Jul 1, 2011 at 10:14 AM
    bcroach78
    TN
    Also interested to know how you put the URD exhaust on your long bed...
  19. Jul 1, 2011 at 10:18 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    I think it's the older MK1 exhaust.
  20. Jul 1, 2011 at 12:32 PM
    ktmrider
    Junk
    It cost me 30 bucks I just had a local exhaust shop add a 13 inch piece of tubing and weld it up. Oh and I didnt like the tail pipe placement so I had them cut the exhaust and move it further behind the rear tire to avoid tearing it up.
    post 18
    http://www.tacomaworld.com/forum/2nd-gen-builds/76648-ktms-build.html
