General Sub Installation
Discussion in 'Audio & Video' started by Burgess, Jul 5, 2008.
  1. Jul 5, 2008 at 9:51 AM
    Burgess
    Burgess [OP] Member
    08 Prerunner SR5
    Running boards, Soon to have subs..
    Can some one tell me step by step how to install my sub into my 2008 Acess cab taco? or is there a sticky that show how to?
  2. Jul 6, 2008 at 1:36 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    Might be helpful to know what you have and where you are wanting to install it.
  3. Jul 7, 2008 at 8:33 PM
    Burgess
    Burgess [OP] Member
    08 Prerunner SR5
    I have a twelve inch kicker cvr. im just talkin basic wiring really. the rest is pretty self explanitory due to personal preference...
  4. Jul 7, 2008 at 8:54 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    It's not really basic. Well...it kinda is, but we still need more info.
    Is it a Dual 2 or Dual 4 (voice coil)?
    If you feel like looking it up yourself, my first place to go is always www.the12volt.com
  5. Jul 8, 2008 at 8:34 AM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    1.Run a fused power wire at least 8G to the amp (but the gauge depends on the AMP SIZE you are running.)
    2.Then Find a spot to Attach your Ground wire directly to the unpainted metal section of the vehicle.
    3.Run RCAs to your AMP from the preouts on the back of your HU (I would suggest not running them with your power wire.. just for sound quality)
    4.Run a Remote wire (switched 12v) from the back of the deck or another switched 12v location (The back of the deck or HU is the most common place.)
    5.Connect your speaker wires to your sub(s) from the AMP
    (How you want to hook up your Subs will depend on how you connect the speaker wires. ie Bridged, Stereo, getting a certain ohm setting etc.)
    6.Connect all other wires then go put the fuse in the power wire and test the system.
  6. Jul 8, 2008 at 4:07 PM
    sooner07
    A A Ron
    DFW, Texas
    Perhaps I am being nitpicky on a forum that doesn't really care about this too much; but I would like to make some comments on this.
    1. Yes, a fused power wire is needed. The fuse should be no more than 18" from the battery terminal (closer is always better). 8 awg is appropriate, but amp "size" doesn't matter. It is the current draw from the amp combined with the distance of power wire needed to reach the amplifier. Probably what you meant, but just adding some clarification because a 1000w class d amp will draw far less current than a 1000w a/b. So it is the current draw that matters in this case.
    2.You are correct, and closer to the amp is best (generally less than 3' is ideal and something that connects to the frame is ideal)
    3.Your suggestion of running power wire seperate from RCA's is iffy if just considering sound quality. You are exteremly unlikely (I've never seen it justified by physics) to have noise induced into the RCAs from power wire and most noise issues associated with this situation are ground wire connections not being adequate. I do typically run mine on opposite sides of the vehicle, but that is because it is generally easier to tuck and hide wires in the cable runs on either side.
    4.Correct; the remote turn on is generally the blue wire from the wire harness off of an aftermarket headunit. However, if you do not have an aftermarket head unit, there are some open switched fuse slots available (just put a small 7.5 amp fuse inline with the remote lead if you use a spade connection to the fuse panel).
    For Burgess let us know what the voice coil configuration is on the subs (dual 2ohm, dual 4 ohm, or something else if that is the case) and what the amp's lowest stable configuration is . (often times it is 2ohm mono, but sometimes 4 ohm mono, which can change how you wire the load.)
    5.No issue here.
    6. No issue here.
  7. Jul 11, 2008 at 2:52 PM
    Burgess
    Burgess [OP] Member
    08 Prerunner SR5
    I do believe it is a four ohm. the lowst configuration is byond me though..
  8. Jul 11, 2008 at 5:20 PM
    Johnson8537
    Oregon
    Agreed on the above... I figured if he was asking for BASIC install questions i didn't need to go into detail..
    As for the power wire and RCA i just do it... I had one vehicle that did it and since then i have just always done it. you are corrent it was actually the amps ground producing sound.
    Burgess - What Amp are you running model number and we can help you from there.. Are you running a single sub or dual?
  9. Jul 14, 2008 at 5:33 AM
    sooner07
    A A Ron
    DFW, Texas
    I figured as much. I wasn't calling you out or saying anything you told him was an outright lie. Just clarifying what you had said and clearing up some misconceptions (the RCA v. noise issue). :cool:
  10. Jul 14, 2008 at 9:08 AM
    Johnson8537
    Oregon
    :D i figure sometimes less clarity for newbies is better just a how to with no reasons why... they can ask if they want. :) we are all here to help!
  11. Jul 14, 2008 at 9:21 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    agreed. I'm notorious about too much info when I really know the subject. Your post was a good instructional.
