Gentex 453 Mirror and temp sensor install in 2014 Off Road - Pictures
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MustDrive, Dec 20, 2013.
  1. Aug 15, 2022 at 10:19 AM
    #121
    Maryland TRD
    Maryland TRD Member
    So I did the mirror swap with temp sensor install a couple weeks ago. Now all of a sudden I am getting intermittent times when the temp drops from current temp of 70-80 degrees to 30 degrees. It seems to reset after some time. It’s completely random so far. Only common thing I have noticed is that the temps are in the 70’s f when this happens. Any ideas??? Faulty sensor? I checked and there is no obstruction or debris on the sensor. It’s mounted on the center pillar in front of the radiator just above the AC sensor.
  2. Aug 15, 2022 at 10:20 AM
    #122
    msgtstocks
    msgtstocks Cyber Geek
    Arizona
    2014 Toyota Tacoma 4X4 TRD
    Added: Steelcraft 70-13370 Elevation Bullnose Front Bumper and a Rough Country 9500 Winch with Synthetic Rope. Bilston 886 Coils and 5100 Shocks. Finished with ToyTec 2" add on springs in the back. All level now
    There was an upgrade to the sensor. I had the same issue.
  3. Aug 15, 2022 at 10:24 AM
    #123
    Maryland TRD
    Maryland TRD Member
    So you just ordered a new sensor and installed again? Thanks
  4. Aug 15, 2022 at 10:27 AM
    #124
    msgtstocks
    Arizona
  5. Aug 15, 2022 at 10:28 AM
    #125
    Maryland TRD
    Maryland TRD Member
    That’s who I ordered the mirror from!!! Thanks
  6. Aug 15, 2022 at 10:38 AM
    #126
    msgtstocks
    Arizona
    I did mine in 2018. They found that the sensor had changed and sent me another. I had the same issue. It was 128 degrees here and the sensor showed 70.
