Gettin Hitched
Discussion in '1st Gen. Tacomas (1995-2004)' started by pidro_el_pirata, Dec 6, 2010.
  1. Dec 6, 2010 at 5:13 PM
    pidro_el_pirata
    pidro_el_pirata [OP] Well-Known Member
    My truck, that is. I don't have a hitch receiver, all i have is the bumper ball, and i've used that for a few trips with a motorcycle trailer but its awkward and i cant turn very sharp without denting the bumper. Has anyone added a hitch to their taco? What hitch did you get, did you install yourself, how hard was it? Looking online it seems my choices are Hidden Hitch, Curt, Reese, Valley, and UHaul hitches. I am trying to decide between these. Does anyone have any experience that would help me out?
    Based solely on internet surfing, I like the look of the round tube ones (Valley and UHaul). But honestly my priorities are cheapest (im a college student), lowest weight (= mpg), ease of assembly (prolly be doing this myself), and quality of manufacture/getting the holes to line up properly. This is assuming they all have the same weight limits, which it seems they do.. I'm looking at class III hitches with a tongue weight limit of 500 lbs and a GTW of 5000 lbs. If i had to choose right now i feel that Uhaul is the most reliable? Thoughts?
    Help?!?! Thanks :D
    edit: Other questions: How much does the average hitch weigh? There are NO numbers online about how heavy they are. Also, I'd love some feedback from 1st gen truck owners in particular, but anything helps.
  2. Dec 6, 2010 at 5:24 PM
    TacoIII
    TacoIII Mr. Boombastic
    Andrew
    Albuqerque
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
    i installed one on my 99 and it was easy i think it was a hidden hitch
  3. Dec 6, 2010 at 5:34 PM
    Ninja14
    Ninja14 Well-Known Member
    Arkansas
    02 Tacoma DC 4x4 TRD OffRoad - 96 4runner 4x4
    YEAH THEY JUST BOLT UP, ITS EASY ...i BOUGHT MINE AT THE U-HAUL PLACE
  4. Dec 6, 2010 at 5:41 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    i installed the Toyota oem hitch and wiring harness on my 03 Taco. Took a while but pretty easy.
  5. Dec 6, 2010 at 5:45 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    i installed the curt on my truck about three months ago. Everything went on with ease, i bought it through jcwhitney for 139.99 i really think they're all about the same just depends on your preference, i was like you, college student, looking for a cheap option and it has worked great so far no complaints
  6. Dec 6, 2010 at 6:53 PM
    pidro_el_pirata
    Did you have to remove the bumper to install the hitch?
  7. Dec 7, 2010 at 7:14 AM
    Ninja14
    Arkansas
    all you have to do is cut the rear bumper and some off the rear fenders too, then they start to rust and fall off......
    :D
    Just kiddin...it goes below the bumper
  8. Dec 7, 2010 at 7:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm a 2nd Gen so I can't say anything about the install but I've added hitches to my '07 and lots of other past vehicles. I've always bought Hidden Hitch and the install has been very easy. Wiring for a 4-pin connection can be purchased as a plug and play kit that T's into your truck's wiring harness for your tail lights. 4-pins or flat fours, as you could have guessed, have 4 wires (2 for signals, 1 for brake lights and 1 for running lights) and are for trailers without brakes or with surge brakes like a Uhaul. If you need a 7-pin, the wiring gets a little more fun since you'll need a power feed and also a brake controller on top of the wires required for running lights, brakes and turn signals.
  9. Dec 7, 2010 at 7:59 AM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
  10. Dec 7, 2010 at 9:05 AM
    pidro_el_pirata
    Johnnie, that's classic! What brand was it?
  11. Dec 7, 2010 at 9:18 AM
    Johnnie
    I.E. SoCal
    Feds
    Lol. Since I don't drive my truck to work it was the only way I could get it home. It was a pain in the ass to carry and since it was used it was dirty and by the time I got home, I was dirty in my work clothes.
    It's a Hidden Hitch. On e-trailer.com they have a video on how to install the hitch and wiring harness.
  12. Dec 7, 2010 at 10:44 AM
    phidauex
    phidauex Well-Known Member
    Sam
    Boulder, CO
    '96 4x4 V6, manual, 201k
    Small lift and a topper!
    I recommend the Valley hitch - I looked at a lot of them, and while they all seem easy to install and use, the Valley looked the most "stock", and was among the cheapest. Easy install too, since you put the mounting brackets on first, then the body of the hitch, meaning you don't have to hold the entire hitch up while mounting the side brackets. Was fairly easy to do by myself.
    For wiring, the Hoppy wiring kit works well - it is cheap, and doesn't require you to splice any wires - it just plugs in between the wiring harness and the taillight plugs. It was very easy, and is 100% reversible if you ever needed to get rid of it.
    I actually ended up with two of these wiring kits while setting my hitch up - I'll sell the other one cheap since it is in my way - $20 shipped if you want it! Here is the original sale post: http://www.tacomaworld.com/forum/bu...ler-wiring-adapter-1st-gen-tacoma-pickup.html
    -Sam
  13. Dec 7, 2010 at 11:36 AM
    Johnnie
    I.E. SoCal
    Feds
    I'm not sure how I'd feel about a two piece hitch. If you have someone to help you install the hitch, then it's easy. I was doing it by myself until my neighbor showed up.
  14. Dec 7, 2010 at 11:47 AM
    Pugga
    Massachusetts
    I'm with you, not really sold on modular receivers. The one piece receivers are very easy to install, I got mine on in under an hour by myself in the apartment parking lot. Something like that Hoppy kit is a great set-up if you only need a 4-pin wiring harness. That's what I have currently on my truck(not sure about the brand but same set-up) and it's completely plug and play and reversible as the other guy pointed out.
  15. Dec 7, 2010 at 12:12 PM
    phidauex
    Sam
    Boulder, CO
    The way the Valley is built, I have no concerns about it. The attachment system, despite being modular, is very beefy. I've towed quite a bit with it, as well as doing some other non-recommended activities like jacking the truck up, or pulling a box truck out of a ravine, and it has never deflected or shifted. There had been some minor tweaking to the rear frame on my truck, and without the modular assembly, it would have been very difficult to get everything in place. I appreciate it's higher ground clearance, as well.
    -Sam
  16. Dec 7, 2010 at 3:30 PM
    pidro_el_pirata
    I'm leaning towards Valley. I like the tube style and the way that it bends up out of the way, unlike the square tube ones like Hidden Hitch and Curt. Like someone up there said, they all seem the same, just different aesthetics.
  17. Dec 8, 2010 at 3:56 PM
    pidro_el_pirata
  18. Dec 8, 2010 at 4:22 PM
    pidro_el_pirata
