Getting from 3" to 5"
Discussion in 'Suspension' started by Dixiepek, Sep 9, 2010.
  1. Sep 9, 2010 at 9:48 PM
    Dixiepek
    Dixiepek [OP] Member
    Columbia, SC
    3" Toytec Spacers and AAL's
    i have a 3" toytec with front spacers and rear aal. how would i go about getting to 5" of lift in a relatively inexpensive way
  2. Sep 9, 2010 at 9:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    A Drop Bracket lift of your choice would be a start. Only RCD makes a 4.5", the rest are 6"
  3. Sep 9, 2010 at 9:49 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    What model and year is your truck??
    If your a prerunner I'd say Camburg's 4" Spindles and Bilstein 5100s and you wouldn't need new UCAs
  4. Sep 9, 2010 at 9:50 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    inexpensive=body lift
    quality= drop bracket
  5. Sep 9, 2010 at 9:51 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    if you are 2wd spindles...otherwise RCD 4.5" like me
  6. Sep 9, 2010 at 9:52 PM
    ColtsTRD
    Scott
    AZ
    yup
  7. Sep 9, 2010 at 10:03 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
  8. Sep 9, 2010 at 10:04 PM
    Dixiepek
    Columbia, SC
    It's an 03' 4WD Extended Cab. The Stepside version
