Getting Stuck ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DiggerRon, May 9, 2018.
  1. May 9, 2018 at 8:22 PM
    DiggerRon
    DiggerRon [OP] Digger
    Ron
    USA Michigan
    2015 AC 4x4 Tacoma
    Cut 4'' from front mud flaps, Applied Fluid Film to frame for rust preventative,
    I went turkey hunting today got stuck bad in mud and water. the Tacoma was in the water and mud for about 2 hours. After getting it out there seems to be some light noise in rear. We had a bad storm here so I haven't been able wash it yet. Those OEM tires suck for mud. I need good some advice.??
  2. May 9, 2018 at 8:23 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Get mud terrain tires for mud
    TireFire likes this.
  3. May 9, 2018 at 8:24 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Drain out your rear diff fluid/gear oil, and change that fluid out (if the water was up above the rear axle)
    These trucks call for 75w-90, but i use Lucas 85w-140 and it works great too..
    Then do the rear diff breather mod
    REDdawn6 and lo2hi like this.
  4. May 9, 2018 at 8:24 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Wash it and see if the noise goes away?
  5. May 9, 2018 at 8:36 PM
    Stewbuff
    Stewbuff Well-Known Member
    Andrew
    Centerville, UT
    '05 AC TRD OR Impulse Red
    Diff Breather Extension
    What kind of noise
  6. May 9, 2018 at 8:39 PM
    tcjacado
    tcjacado Well-Known Member
    Could be mud in the tire or the brake drum.
  7. May 9, 2018 at 8:43 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    How high was the water?
  8. May 10, 2018 at 8:03 PM
    DiggerRon
    Ron
    USA Michigan
    2015 AC 4x4 Tacoma
    Well TY guys for the advice on my truck. I washed it I think the sound was the drum brakes. Every thing seems good TY.
    BassAckwards and tcjacado like this.
  9. May 10, 2018 at 8:07 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    DustStorm4x4[QUOTED] likes this.
