Getting the Rear Leaf TSB Dealer Run Around ... Ugh
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZanexGt, Oct 28, 2010.
  1. Oct 28, 2010 at 5:24 PM
    ZanexGt
    ZanexGt [OP] Well-Known Member
    Fairfax, VA
    2019 DCSB TRD Off Road
    Hey all,
    I bought my truck last week, new, and it has approximately 200 miles on it. I do not drive much to/from work, maybe 10 miles at most.
    Anyway, I bought my truck to haul 'stuff'. You name it, trees, mulch, firewood, engines, and to tow a boat and trailer.
    Needless to say, I want the Rear Leaf spring TSB.
    So I went to Kay Jennings Toyota today in Alexandria, VA. The service manager told me that I need to bring my truck in so that they can 'inspect' my claims of the bed sagging under load.
    Sounds like a 'load of you know what' to me.
    I was nice but disappointed. I just knew I would get the dealer run around on the Leaf Spring TSB. I mean, what am I supposed to do? If they look at my suspension, it looks brand new, there won't be any wear, especially to the bump stops.
    So....Should I bring it to Kay Jennings and go through their rigamarole? Should I try another dealer? (anyone in the No. Va area have recommendations?) or should I call Toyota and see what they can do?
    My expectation was to go in, talk to the service manager, listen to some B.S., and then they would order the parts / setup a time for installation. Lastly, I brought a copy of the TSB with me.
    Anyway, I know I will need the spring TSB, I bought the truck to be a truck!
    Anyone got opinions? Thanks!
    -Robert
  2. Oct 28, 2010 at 5:37 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I did have to call toyota corp after they denied me at first, so that will be your next step.
    research the site, there are plenty of threads on the subject.
    try this line, i used it when they wanted me to do the same thing;
    WHY WOULD I WASTE MY TIME AND MONEY
    PUTTING WEIGHT IN THE BACK OF MY TRUCK
    FOR A PROBLEM THAT HAS ALREADY
    a. BEEN IDENTIFIED FOR THE LAST 5 YEARS AND
    b. ALREADY HAS A TSB ISSUED FOR THE REPAIR OF IT????
    after agreeing to do the TSB, they tried to give me the ride will be alot firmer speech
    I stated - Oh, more like a truck?
  3. Oct 28, 2010 at 5:41 PM
    ZanexGt
    Fairfax, VA
    That's what is weird about their request, they don't want the truck loaded, they just want their techs to inspect the truck.
    Oh and they already tried the whole 'the ride will be so firm you won't like it' bit on me. I politely told them I bought a truck not a luxury car. :)
  4. Oct 28, 2010 at 5:45 PM
    skistoy
    Western New York
    your may want to research the part numbers of the rear springs on your truck
    you should still be able to see them seeing its new, probably on the top side.
    if your spring part numbers match the ones listed on the TSB
    they really have no grounds for not doing the TSB
  5. Oct 28, 2010 at 5:48 PM
    ZanexGt
    Fairfax, VA
    That's a good idea, I am going to crawl under the truck tomorrow and take a look. I'll snap some pictures too if possible.
  6. Oct 28, 2010 at 5:58 PM
    Yota1
    Yota1 Well-Known Member
    bottom it out, the bump stops will leave marks, say you felt what seems like it bottomed out under "X" lbs. Thats what I did, no questions asked, swapped and all good now.
  7. Oct 28, 2010 at 6:17 PM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS
    be persistent, you'll get it if you have the springs that match the TSB part number, tell the dealer either they can call toyota or you can, their choice.
  8. Oct 28, 2010 at 6:32 PM
    KCin HBCA
    KCin HBCA 2020 TRD Sport 4x4
    Keith
    Huntington Beach
    2020 Dbl Cab TRD Sport 4x4
    I was given the same story, they have to have a tech complete the paperwork documenting the complaint and any visible signs of bump stop contact with the frame.
    Just go in with a respectful attitude but be firm. When I suspected they might give me a hard time I reiterated the fact that while I had a load in the bed I felt unsafe driving even the short distance (4 miles) home from Home Depot.
    Be persistent, respectful, and informed when you deal with them and it should be fine. Some people go in with an "I'm entitled" attitude and start off on the wrong foot.
    And if all else fails there is always another level to deal with. It's a hassle if it has to go that far but always maintain a respectful but firm attitude.
    Best of luck, I hope you don't have any problems.
    KC
  9. Oct 28, 2010 at 6:38 PM
    ZanexGt
    Fairfax, VA
    Interesting comments guys. So, the likelihood of me getting denied due to lack of wear on the bumpstops is high? Should I wait until I hit the bumptops w/ a load in the bed (I'd rather not do that).
  10. Oct 28, 2010 at 6:38 PM
    ZanexGt
    Fairfax, VA
    Did you have wear on the bumpstops?
  11. Oct 28, 2010 at 6:40 PM
    Falcon86
    Falcon86 Well-Known Member
    Virginia Beachshire
    Bone-stock
    I've got an '11 Taco and I've been given the runaround by 2 dealerships AND Toyota "Customer Care".
    My solution? Bilstein 5100's all around, AAL in the rear.
    They don't want to do it, I'll do it myself.
    First thing I need Toyota's help with and they won't back up what I just paid a ton of money for. Sucks.
  12. Oct 28, 2010 at 6:44 PM
    Larry
    Larry CARL
    CARL
    1st dealer I went to was stubborn about it...wanted me to leave the truck so they could inspect it. :rolleyes:
    called Toyota...they created a file and gave me a case #...they also emailed the info (including the TSB #) to the service mgr. at another dealership (you choice).
    I then called the dealership service dept. Spoke with a advisor who cleared it with his mgr. to go ahead and order the parts and allow me to make one trip in for the TSB install. No BS "inspection"
    Hook...line...sinker.......Done.
  13. Oct 28, 2010 at 6:58 PM
    KCin HBCA
    Keith
    Huntington Beach
    I couldn't have had very much, I only drove loaded a couple times. Be persistent and remember the line: "I didn't feel safe driving with even a small load".
    If you just bought the truck from this dealer I would hope they would be very interested in providing you excellent service (have you got the survey yet?).
    Again, be firm but respectful and it'll go a long way. I wouldn't expect any company to blindly replace parts, the inspection is part of the process. Those that have related stories of "I told them about the TSB and they ordered the parts right then" are the exception... not the norm.
  14. Oct 29, 2010 at 3:48 PM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Exactly what I was thinking when the dealer gave me BS about doing the TSB. There's obviously a problem, hence the TSB, and its complete bullshit that this $30k+ truck can't even carry half the weight that it's rated to carry without bottoming out :mad:
  15. Oct 29, 2010 at 3:51 PM
    ballz716
    ballz716 Well-Known Member
    With getting mine done they wanted to inspect. After they did that they brought up the tsb without me saying anything. Then set up a time I could come back to get it done. Also I never had a heavy enough load to hit the bump stops.
  16. Oct 29, 2010 at 4:20 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    I took mine in with no wear on the bump stops or anywhere else, it was brand new too.
    I think they are told to ask questions about harsh ride, etc and tell you they need to inspect it.
    The TSB mentions "harsh ride when loaded" so say that over and over when you go in.
    The service writer (not manager) just said to me, 'so it has a harsh ride when loaded'? I said 'it sure does'.
    They already had all the parts in stock and took the truck in right then and I got it back the next morning.
    Did you buy it at this dealership? You could go tell your sales person/manager you need this TSB done and that the service department is giving you a hard time about it.
  17. Oct 29, 2010 at 4:22 PM
    hwysrfr
    hwysrfr Well-Known Member
    Dennis
    SoCal
    2008 TRD Sport Access Cab
    2" lift Raceline Renegades 17x9, BFG All Terrains 265x70x17 Billet grill with USMC emblem, Redline hood struts
    Don't go to the dealer! Call 1800 number first! Smooth sailing after that!
  18. Oct 29, 2010 at 4:28 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    "The system" is optimized to work as follows:
    1. You experience a problem
    2. You report it to the dealer
    3. The dealer verifies the problem
    4. The dealer fixes the problem.
    When you read about the problem on the internet and try to jump direct to step 4, you're cutting against the grain. So yeah, just load it up heavy, drive it around for a while making sure the load bottoms out a few times, then begin at step 1.
  19. Oct 29, 2010 at 4:30 PM
    Ding King
    Ding King Well-Known Member
    Parts Unknown
    TRD SPORT 4x4
    5100's all around fronts at .85,rear TSB,trans TSB,20% tint,TRD exhaust, TRD CAI,tailgate mod, bed mat, Extang Solid Fold, EGR in-channel, Nitrofil.
    I agree. Stay after them it will work out.
  20. Oct 29, 2010 at 4:40 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Mine was exactly the same. I mentioned it to them, told them my complaint and the scheduled it with a service I needed. When I picked it up they said the parts were on order and they will call me when they were in. You might just want to let them look at it and see what they say. No point getting all worked up over nothing until they do deny it. Then call corporate.
