GFC SuperLite
Discussion in 'Outdoors' started by CoastalTRD, Jul 21, 2020.
  1. Nov 25, 2022 at 1:41 PM
    #141
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    Managed to snag one last night. This will work perfect with my GFC platform topper that I also ordered, won’t get that one until January though.
    essjay and Camerasandcoffee like this.
  2. Nov 25, 2022 at 11:28 PM
    #142
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    The GFC Topper is a solid, lightweight option (and probably very secure, given that there's no windows), but, coming from a Softopper, I want to be able to remove the Superlite and use the bed for truck stuff.
    As a result, I'm looking at Leitner or Yakima Overhaul with Decked, or the Overhaul on a Retrax. I like the idea of Decked, but it weighs 225lbs on a 6' bed. I also like the idea of the Retrax, but I'm not sold on the offroad durability of mounting a rack and RTT to the tonneau rails because every review out there seems to be on a truck that spends more time at the mall than on a rough trail. The Yakima seems like a good choice because it's light (55 lbs?) and you can adjust the height so that it's very low compared to a Leitner or a shell.
  3. Nov 26, 2022 at 12:06 AM
    #143
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    I want to be able to do the same, I’m looking into the GFC Chase Frame. I emailed GFC yesterday to see if they have any available to ship as their site states first units shipping late summer ‘22 but looks like their still taking deposits. Otherwise I’m thinking of using the Yakima Overhaul bars until I can get a chase frame.
  4. Nov 26, 2022 at 3:23 AM
    #144
    Camerasandcoffee
    Camerasandcoffee 900hp short of 1000hp
    Jonathan
    Racine WI.
    2019 Trd Sport
    Relentless Fab hybrid bumper, 2.5” Dobinsons IMS lift, RCI skids and sliders, block heater. Painted FJ Steelies. Was trying to keep it stock, now slowly building for the Wisconsin trails.
    I'm thinking along similar lines. I plan on mounting to my Rola Haul-Your-Might rack at least initially. I may need to make some kind of side bar/support plate between the front and rear to provide some stiffness.
    Like you I want to keep it modular and removable for hauling big items when needed.
  5. Nov 28, 2022 at 9:15 AM
    #145
    essjay
    Concord, CA
    I ended up cancelling my order this morning after marinating on it this weekend while camping in the snow. When you factor in the cost of mounting and secure storage, it simply doesn't check enough boxes for me.
  6. Nov 30, 2022 at 6:45 PM
    #146
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    You should uncancel your cancel and sell it, like to me.
  7. Dec 14, 2022 at 1:48 PM
    #147
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    I was in total agreement with both of you until I changed the orientation of the poles. The velcro straps were actually long enough when I had the wider section on the bottom. However, this puts the cam lock higher up on the pole, which may be an issue for height-challenged individuals.
    You may want to check and see if this may be your issue, too.
    boston23[QUOTED] likes this.
  8. Dec 15, 2022 at 8:49 AM
    #148
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    The only downside to this tent is the damn poles. I really wished they were hydraulic.
    Lord Helmet likes this.
  9. Dec 15, 2022 at 1:49 PM
    #149
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    For me the only downside is that the fabric exterior will eventually break down from UV damage. Def not a hardshell, idk why they market it that way.
    I’ve been applying the aerospace 303 UV spray but may order a custom cover.
  10. Dec 15, 2022 at 2:10 PM
    #150
    gwiz
    gwiz Well-Known Member
    Indiana
    2020 Tacoma SR5 4x4 V6
    GFC v2
    I heard on the GFC forum that they sell replacement covers.
  11. Dec 15, 2022 at 2:11 PM
    #151
    dezert.taco
    Nate
    Northern Nevada
    2018 Tacoma
    I mean it's certainly a hardshell but it is kinda a bummer it has fabric over it. GFC does sell replacement outer fabric for $650 and they do state that the fabric is a consumable and not something to be expected to last the life of the tent.
    Camerasandcoffee likes this.
  12. Dec 27, 2022 at 4:45 PM
    #152
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    My only grip when I setup the tent
  13. Dec 28, 2022 at 1:54 PM
    #153
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Takes 2 seconds
  14. Dec 31, 2022 at 3:32 AM
    #154
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    I've only set mine up twice so far and once was on the garage floor. I'm sure it will get easier once I've done it a few more times.
    I was thinking I might mark the poles in some way at the correct extension and extend them to that before lifting up the top part. Dunno, I need to play around and find what works best.
  15. Jan 2, 2023 at 1:26 AM
    #155
    Lord Helmet
    Nick
    '24 X3 M40i
    If you had hydraulics
  16. Jan 3, 2023 at 9:52 AM
    #156
    Nomad26
    Escondido, CA
    It is kinda a pain. Also when you realize that you need to flip the poles over so the beefier side is at the bottom. Otherwise the Velcro straps don’t fit around the poles. But what I have done is access the pole on the passenger side, prop it up then climb into the tent to get them both propped up before opening them all the way. Takes about 5 minutes. Not as easy as a hydraulic strut for sure but it’s not too bad.
  17. Jan 3, 2023 at 3:30 PM
    #157
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    Does anyone have suggestions for outfitting the interior of the Superlite?
    I'm wondering what peeps are using for lights, iPad holders, interesting ideas, etc.
  18. Jan 4, 2023 at 5:56 AM
    #158
    gwiz
    Indiana
    GFC v2
    Camerasandcoffee and Nomad26 like this.
  19. Jan 4, 2023 at 10:43 AM
    #159
    Camerasandcoffee
    Jonathan
    Racine WI.
    2019 Trd Sport
    gwiz[QUOTED] likes this.
  20. Feb 6, 2023 at 9:59 PM
    #160
    cactushead
    San Diego
    One of my main complaints about the SuperLite is that wasn't designed to mount accessories on top of it. Other than a flexible solar panel, there's very few things that can be mounted over the SuperLite.
    As a result, I haven't been able to take my kayak out. I finally figured out a way to mount my kayak racks without touching the SuperLite! This setup will now enable me to go on trips with my kayak in tow.
    Here's a link to the write up in the "How are you mounting your kayaks" thread.
    bulalo and Camerasandcoffee like this.
