Gifted Bilstein 6112, not sure what I need from here.
Discussion in 'Suspension' started by tijuanataco17, Jun 10, 2020.
  1. Jun 10, 2020 at 10:41 AM
    tijuanataco17
    tijuanataco17 [OP] Well-Known Member
    Andres
    2020 TRD Offroad 4x4
    Recently gifted Bilstein 6112's w/ coilovers for my truck. I understand this provides a 2 inch lift.
    I was told I should buy 5160 for the rear so I have a relative even lift.
    What else do I need? UCA's? Add a leaf? I wish to have all the required parts before I take it in for installation.
    Info is much appreciated!
    HeadStrong Off-Road and uurx like this.
  2. Jun 10, 2020 at 10:43 AM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Just an AAL or rear block. You don't necessarily need 5160's you could go 5100s in the rear w/out the remote resi. If you go less than 3'' UCAs arent necessary for a decent alignment.
  3. Jun 10, 2020 at 10:44 AM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    UCAs aren’t needed if you stay under 2”, but I would get them for peace of mind. AAL will left the rear and the 5160 is a great option to pair with the 6112. If you plan on adding armor or weight in the back, go for a full leaf pack over an AAL.
    edit: don’t forget to pick up a new needle bearing from ECGS
  4. Jun 10, 2020 at 10:49 AM
    TacoBuffet
    AL
    Needle bearing is hit or miss, some guys need it some guys don't, Chitown4x4 told me it was a load of cr*p and not to bother (lots of experience with yota builds), I never needed it on my 11, 15 or 19, but if you're in there, the piece of mind may be worth it. UCAs aren't really piece of mind just a waste at under 3'', as the stock UCAs are well built and you can get a decent alignment within spec at that height. Anything at 3'' or above I would agree that UCAs are a must, you can go without, but truck will handle like sh*t. Of course if you are wheeling hard than UCAs are great, but for most under 3'' is just wasted money. Good call on the full leaf pack with armor / additional weight.
    tijuanataco17[OP] likes this.
  5. Jun 10, 2020 at 11:09 AM
    tijuanataco17
    Andres
    Im not running much weight in the back, couple surfboards and some camping equipment, maybe 300 pounds total, and thats once in a while. Should I go for the full leaf pack or stick to the aal? Also, I was told that air bags would be recommended? Im not sure what for.
  6. Jun 10, 2020 at 11:12 AM
    TacoBuffet
    AL
    No on the airbags and I'd stick to just an AAL, I had 2 dirt bikes and gear in mine with just an AAL every weekend no problems.
  7. Jun 10, 2020 at 11:13 AM
    304_Taco
    304_Taco Well-Known Member
    Curtis
    Morgantown, WV
    16 TRD Sport DCSB MT
    An AAL should suffice based on that. Main reason for a full leaf pack is usually because people keep a loaded bed or an bed rack RTT or both so the extra support is necessary.
    Air bags are typically towing related so I'd say you'll be good without them
  8. Jun 10, 2020 at 11:13 AM
    tijuanataco17
    Andres
    Much appreciated info man. Should I go for the old man emu aal? read good things about them.
    TacoBuffet[QUOTED] likes this.
  9. Jun 10, 2020 at 11:22 AM
    TacoBuffet
    AL
    Yep thats a good one. I ran a deaver with no problems in all 3 trucks. Make sure you get the extended ubolts.
    In&out likes this.
  10. Jun 10, 2020 at 11:29 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    Yep that's good man, will totally work for you. now hurry up and buy it before the expo guys come in here and tell you you need full Kings because they haul their overland cooler in their beds 3x a year
    HD1911, Island Cruiser and TacoBuffet like this.
  11. Jun 10, 2020 at 11:29 AM
    TacoBuffet
    AL
    :thumbsup::rofl:
    Island Cruiser likes this.
  12. Jun 10, 2020 at 11:31 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    if you got 6112 for free, just skip the AAL and throw the arb leaf pack in there... its worth the few bucks since you already are ahead of the game and they are the proper complement to those nice 6112
    just my .02
  13. Jun 10, 2020 at 11:31 AM
    TacoBuffet
    AL
    Yep, gotten worse it seems with the 3rd gen crowd, all these first time truck / tuner car guys dropping crazy money on setups they don't really need to be IG worthy, nice builds though.
    In&out likes this.
  14. Jun 10, 2020 at 11:55 AM
    tijuanataco17
    Andres
    Awesome man, thank you.
    I found two different ones on Headstrong offroad, but I cant seem to find the difference between them.
    https://www.headstrongoffroad.com/store/p279/OME_Add-a-leaf_(PAIR)_-_EL46XL_.html
    https://www.headstrongoffroad.com/store/p465/OME_Add-a-leaf_(PAIR)_-_D29XL_.html
    and last but not least, is this the correct ubolts?
    https://www.headstrongoffroad.com/store/p106/Extended_length_U-bolts_-_05__Tacoma.html
    HeadStrong Off-Road likes this.
  15. Jun 10, 2020 at 1:24 PM
    TacoBuffet
    AL
    Not familar with those leafs or difference, couldnt figure out myself, hopefully someone can chime in. Ubolts are correct!
  16. Jun 10, 2020 at 1:36 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    I would get the new @HeadStrong Off-Road 3 leaf AAL. No cutting/modification to your existing pack needed. If this was available when I did mine I would have gone this route instead of cutting the rivet/bracket off the stock pack. The 3 leaf AAL is said to ride better than the single leaf AAL. I have the 6112/5160 setup with the 3 leaf and love it.
    https://www.headstrongoffroad.com/store/p1239/HS_1.5"_lift_3_leaf_AAL_with_u-bolts_(PAIR)_-_HS-TOY516-3AL.html
    https://www.tacomaworld.com/threads/now-available-all-new-redesigned-hs-3-leaf-aal.658544/
    Edit - the 6112s allow 0-2.5" lift depending on setting chosen
  17. Jun 11, 2020 at 12:58 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Just to throw my .02 in here, OP should probably also think about what kind of ride quality he wants before deciding on his rear upgrade.
    Going from a stock leaf pack, the add-a-leaf is going to stiffen up the ride some, and a Dakar pack with no extra weight is way too stiff for many. Ask me how I know.
    If he wants to keep the relatively cushy stock ride, he'll be better off with a Deaver or custom leaf pack that gives him the ride height he wants, and then tailor his rear shocks to that set-up.
  18. Jun 12, 2020 at 11:39 PM
    tijuanataco17
    Andres
    When you say a Deaver, is that the single add a leaf?
  19. Jun 13, 2020 at 12:46 AM
    LC7
    Far Nor Cal
  20. Jun 13, 2020 at 9:27 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank your for your recommendations @WrecklessAbandon we truly appreciate it! :fistbump:
