Glasspacks
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaprerunner, Nov 23, 2010.
  1. Nov 23, 2010 at 8:07 PM
    tacomaprerunner
    tacomaprerunner [OP] Dang liberals.
    1995 Ford F350 7.3L PowerStroke Diesel
    Alright I'm gonna be 'that guy' and probably start a vicious one sided debate on why not to throw a glasspack on a 3.4, but let's at least try for a civil disussion.
    I understand that a lot of people consider a glasspack on a V6 to be 'ricey'. That's your opinion. I see (hear) both sides of that argument.
    I also understand that a 6 cylinder will never sound as 'deep' or 'throaty' as an 8 cylinder.
    So basically what I'm saying is talk to me. I'll listen and consider whatever you got to say. A few friends of mine really suggest throwing one on there, but I'm a little skeptical.
  2. Nov 23, 2010 at 8:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Glasspacks are kinda "Old school". You can get better sound, and performance, from a tuned muffler, or cat back.
  3. Nov 23, 2010 at 8:17 PM
    tacomaprerunner
    In terms of performance, is that a reference to the lack of back pressure from a glasspack?
  4. Nov 23, 2010 at 8:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On modern engines, "Back pressure" is not really aplicable. "Back pressure" would mean a restriction. The exhaust performs best when Scavenging is optimized. Many "Performance" exhaust systems or mufflers can maximise the engines scavenging, and give a slight gain in hp/tq. Glass packs simply let the exhaust flow straight thru, and kill the bottom end hp.
  5. Nov 23, 2010 at 8:25 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I have one inline with my muffler to eliminate rasp and I am very pleased with it.
  6. Nov 23, 2010 at 8:26 PM
    tacomaprerunner
    How significantly?
  7. Nov 23, 2010 at 8:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You will notice it.
  8. Nov 23, 2010 at 8:27 PM
    tacomaprerunner
    Before the muffler I assume?
  9. Nov 23, 2010 at 8:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Used in this mannor, they work well.
  10. Nov 23, 2010 at 8:28 PM
    tacomaprerunner
    Roger that. Thanks for the input
  11. Nov 23, 2010 at 8:30 PM
    memario1214
    Colton
    Missoula, MT
    It is not terrible, but low end you will notice it. I'm convinced that I have higher top end though.
    That is correct. Videos of my truck are in my sig if you're interested. I also have an "exhaust build" thread floating around here somewhere if you are at all interested.
  12. Nov 23, 2010 at 8:42 PM
    tacomaprerunner
    Checked out the videos. That sounds great man. I found this on YouTube after watching your videos - this is a 3.4
    http://www.youtube.com/watch?v=CxG8I94pCzk&feature=related
    edit - and is this the link you were talking about?
    http://www.tacomaworld.com/forum/pe...ting-my-cats-adding-aero-turbine-muffler.html
  13. Nov 24, 2010 at 10:43 AM
    ak.rideon
    ak.rideon Well-Known Member
    Scott
    Seward AK
    98 tacoma sr5 limited
    98 limited with air raid throttle body spacer, volt 4300k hids, vortec muffler, magnaflow spun cat, clear corner lights, led tail lights, alpine cda-117, alpine type r 10 in a sealed box and a alpine 500w mono amp.
    imo i think glasspacks sound alright but i do agree that they are more "old school." i wouldnt put a glasspack on a 3.4 but on the other hand i would def put glasspacks on an old ford. but everyone has different prefrences if u know what i mean.
    And that aero turbine 2525 sounds very nice and clean on a 3.4. i saw that you tube vid and loved it from the first time i heard it.
  14. Nov 24, 2010 at 10:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  15. Nov 24, 2010 at 3:01 PM
    tacomaprerunner
  16. Nov 24, 2010 at 3:16 PM
    memario1214
    Colton
    Missoula, MT
    Stay the same size as long as all other engine components stay the same. If you boost a vehicle, then piping size changes make more sense...
  17. Nov 24, 2010 at 3:25 PM
    tacomaprerunner
    Ya I decided to rule out a glasspack. Did some more research and talked to a guy at O'Reillys, and the overwhelming majority of information basically considered them outdated. From what I've read and heard from people, it'll sound good for about 4 months, but by then most of the fiberglass will have blown out and it'll sound worse than what I began with.
    I know some guys on here are running glasspacks and haven't had any problems. That's great, but it's not something I really wanna deal with now. I'll probably throw on a Flowmaster 40 series in the near future - for performance and sound.
  18. Nov 24, 2010 at 4:10 PM
    memario1214
    Colton
    Missoula, MT
    The lack of longevity on them is exactly why I bought a larger one and installed it in reverse. It sounds counter-intuitive, but it still works well and I see it working at near full potential for a couple years minimum. But ruling it out is your call... I am just trying to guide you with what I know/have learned. Good luck, let us know how it goes, and let me know if you have any questions!
  19. Nov 24, 2010 at 4:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This ^^^
  20. Nov 24, 2010 at 4:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, On the Tacoma V6's, Ive found that you can go up to a 2.5" pipe before you start to loose any low/mid range hp. Going larger than 2.75", the loss begins to negate the gains in the upper rpms, IMHO.
