Glove Box Light Bulb
Discussion in '1st Gen. Tacomas (1995-2004)' started by Albinator, Jul 14, 2015.
  1. Jul 14, 2015 at 8:12 AM
    Albinator
    Albinator [OP] Well-Known Member
    Utah
    2000 Tacoma 2.7 Manual SR5 4x4; Manual Hub
    Alright, researching these forms it shows that my vehicle (and others on here) uses the #74 Bulb for the glove box light.
    I ordered one and it doesn't fit. Come to find out after examining the blown bulb, it was labeled a number #27. Why would this be and where can I find this number bulb?
  2. Jul 14, 2015 at 9:43 AM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    I bought a bag full on ebay, I put them in the glove box, ashtray, and behind the HVAC control panel (I may have to remove the leds from their original plastic base and put them in the old base that screws into the HVAC board for this - easy). Most of the ebay sellers have pictures, use them to compare to the old if you still have it (check the ashtray as they are the same). If you think you want to take them apart, make sure you get the plastic base with wires, opposed to the soldered to a tiny piece of circuit board type. You can tell the difference easily by the pics.
    regardless there are tons of each type on ebay.
  3. Jul 14, 2015 at 10:29 AM
    Albinator
    Utah
    A bag of the #74 or #27 bulbs?
  4. Jul 14, 2015 at 10:45 AM
    travelfeet
    Andrew
    Troy, NY
    02 xtra 4x4 v6
  5. Jul 14, 2015 at 10:57 AM
    Albinator
    Utah
    When I fill out the part that says to put in your vehicle to make sure it fits it tells me "This part is not compatible with 2000 Toyota Tacoma SR5 Extended Cab Pickup 2-Door 2.7L 2694CC l4 GAS DOHC Naturally Aspirated."
  6. Jul 14, 2015 at 11:08 AM
    travelfeet
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    If I hazard guess its because the seller's search is looking at dashboard lights, I don't know what they are in your dash, but the ebay leds are probably not the same size as Tacoma dash bulbs (the one's behind the HVAC panel for mine were shaped differently too, but like I said, I was able to swap them with a little work). I suggest pulling out the burned one from the glove box or ash tray and comparing to the pics. They are hard to see in their sockets, just little nubs. The originals look like a glass grain of rice, but the base has the same flat shape with a single wire contact on each side as the ones in the pics (like a small Christmas tree bulb). In the end, as long as they are 12 volt (all the car LEDs are) and you can make contact, they will work. Whether they stay is the socket is the only real issue.
    If you are new to messing with LEDs, you should know that many of them have to be connected correctly. i.e. unlike an incandescent bulb, they only light with current flowing in one direction. Practically speaking, this means if an LED doesn't work, pull it out and flip it around.
    If you have lost the original bulbs, I humbly suggest its worth ~10 bucks to give them a shot. I am pretty sure they work. Notice that they come in different colors though. The ones I linked to were blue, I prefer the white.
  7. Jul 14, 2015 at 11:33 AM
    travelfeet
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    Albinator, I just reread your original post and I think I misunderstood. The original bulb you pulled out was a #27 (I thought that was the one you received when purchasing a #74) i.e. got the wrong bulb.
    I do not know what a #27 bulb is. Sorry to send you down the wrong path.
  8. Jul 14, 2015 at 3:06 PM
    Albinator
    Utah
    It's all good. It actually got me to look into the LED because it looks much better. I found the bulb at the Toyota dealership and it's a 74 and looks just like mine that burnt out. So I don't know how the one I received was a 74 if it looked different. Tell you what, I am not impressed with the new bulbs light...I'll check it out tonight to get a better look at it to see how bright it actually is.
  9. Jul 14, 2015 at 6:59 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    My glovebox light is crazy bright and I changed all mine out for leds
  10. Jul 14, 2015 at 7:52 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; mattgecko's Underhood Lighting; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Same here.
    I went with these, from VLEDS, which were a direct, plug & play replacement for the glove box and ash tray bulbs.
  11. Jul 14, 2015 at 8:26 PM
    bellassaiw10
    Currituck NC
  12. Sep 20, 2015 at 5:15 PM
    ThunderOne
    ThunderOne Banned
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Just an FYI, you can get replacement bulbs at any auto parts store. I couldn't find the #74 that it specifies but I did find two types in store that looked identical to the bulb I removed. I purchased the 12505 Philips bulb. It looks like it might actually be a little bit brighter than the stock bulb. The package comes with two so you can do the ashtray and glovebox at the same time. Mine have the tendency to burn out at the same time. I don't use the ashtray bulb though so I'm not gonna replace it.
