Going too extreme???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FLAtacoma05, Nov 7, 2009.
  1. Nov 7, 2009 at 3:17 AM
    FLAtacoma05
    FLAtacoma05 [OP] Well-Known Member
    Wes
    Crestview, FL
    2005 BSP Prerunner DBL Cab
    toytec spacers body lift 315/75/16
    Ive seen tacomas on cardomain with 9" of suspension lift. How is that accomplished? :confused:
    I been thinkin about stacking a 6" pro comp, 3" revtek and possibly a 3" body running 38" tires. Ive been told it cant be done or it will create severe stress on the CV joints or the ball joints. But its strictly for show and will be an everyday driver through town so it wouldnt hurt the angles or stress the ball joints too severe if i get bigger UCAs right?
    Who would be willing to or know of someone to install this?
  2. Nov 7, 2009 at 3:49 AM
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
    you may want to post this in "suspension"..
    there is also a sticky for general information about lifts..
  3. Nov 7, 2009 at 3:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Most folks have gone for a 6 inch lift with a 3 inch body lift to get to 9 inches. I do not think your ball joints would survive adding the 3 inch Revtek spacer on top if the 6 inch drop bracket kit.
    Your prerunner does have the option of lifting with spindles. They will give you 4 inches, then you can add coilovers for an additional 3-3.5 inches.
    Trying to stack suspension lifts is going to give you issues....and on an 05- I'd be amazed to see you clear 38's...even with all that lift. I want photos when you are done!!
  4. Nov 7, 2009 at 4:15 AM
    FLAtacoma05
    Wes
    Crestview, FL
    could you achive 9" with a 6" kit and buy coilovers and adjust them to 3"?
  5. Nov 7, 2009 at 4:42 AM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    6" lift plus 35's get you 8" and it's as close to 9" as I'd feel safe going...
  6. Nov 7, 2009 at 7:46 AM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    anything more than 3" is overkill
  7. Nov 7, 2009 at 7:49 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    yes
  8. Nov 7, 2009 at 4:25 PM
    socaltaco2
    socaltaco2 Active Member
    Might as well go SAS if you want to be that high. Unless its a street queen... in which case you could get a 4" Spindle, 3" coilover and 3" body lift.
  9. Nov 7, 2009 at 5:40 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    surprised no one else caught this.....but ur prerunner has no c's to worry about
  10. Nov 7, 2009 at 5:54 PM
    Vultite
    Vultite Active Member
    FL
    94' Ranger
    add some ladder bars to reduce axle wrap when u lift it...
  11. Nov 7, 2009 at 9:10 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
    I think you should do it :D
    6" lift with 3" coilovers and 3" body lift!! lol
  12. Nov 7, 2009 at 9:13 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    My question is where the hell is that legal :p
    6 inch lift is borderline here.
  13. Nov 7, 2009 at 9:19 PM
    BravesFan
    BravesFan The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    haha just put 9 hockey pucks and u will get 9 inches;)
  14. Nov 8, 2009 at 12:08 AM
    Faskev
    Faskev Well-Known Member
    If the drop bracket in the 6" lift kit keeps your front geometry close to stock then you probably could add coilovers for another 3" inches. The 3" body lift won't affect your suspension, it is just putting spacers between the body and the frame. I think it would be kinda "poseur" being that it's a PreRunner but it would definitely be high!
  15. Nov 8, 2009 at 4:46 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Caught it- cause I recommended the lift spindles- Just didn't say anything.
