Good Deal on Jeep Wrangler???
Discussion in 'Buy / Sell / Trade' started by jjw1, Jul 31, 2010.
  1. Aug 1, 2010 at 11:36 AM
    #41
    jjw1
    jjw1 [OP] Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    oh ok...my bad haha im supposed to go look at it later on today
  2. Aug 1, 2010 at 11:38 AM
    #42
    BAT24
    BAT24 Well-Known Member
    Ohio
    TRD Rugged Trail
    TRD - CAI Sport Hood Sport Grille Sport Headlights OEM LED Tails Factory Roof Rack
    Good luck on it.
  3. Aug 1, 2010 at 11:42 AM
    #43
    jjw1
    Jesse
    thanks!!! we need somethin to tow behind the rv anyways so y not???
  4. Aug 1, 2010 at 11:49 AM
    #44
    IsmellBacon
    IsmellBacon Well-Known Member
    Denver, Colorado
    TRD offroad double cab
    None yet, need to finish the HEEP first
    The Sahara edition has a Dana 44 in the rear NOT the craptastic d35c. With that jeep you are getting the tried and true 4.0L inline 6 that produces great low end torque. The lift and tires work very well with Jeep. If you are going to look at it, make sure the diff's are dry as well as the TC, tranny and oil pan. Look under it for any major scrapes on the skid plate and the lower shock towers. That would indicate it has been in some fairly rough rocks. IF you test drive it, put it into 4wheel high and low to make sure it shifts cleanly. ALSO full turn lock either direction and make sure the tranny and TC bind up (you get resistance) while moving. Other than that is looks like a nice buy, a little inflated because it IS a Jeep but other than that it looks solid.
    Bacon
  5. Aug 1, 2010 at 11:54 AM
    #45
    jjw1
    Jesse
    thanks bacon...i planned on doin everything...i seen it last night at dinner n from the looks of it the owner took good care of it...no rust at all on it either...thanks for the info bout the danas too
  6. Aug 1, 2010 at 3:04 PM
    #46
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The D44 was an OPTION back then. The Rubicon was the only Wrangler that came with Dana 44's from the factory.
  7. Aug 1, 2010 at 3:40 PM
    #47
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Seems like a nice jeep! GET IT!!!!! :thumbsup:
  8. Aug 1, 2010 at 3:50 PM
    #48
    cgs2k2
    cgs2k2 old man
    Looks good! I'd say he/she should be able to let it go for 7500? That would be a good price for both you and the seller IMO.
  9. Aug 1, 2010 at 6:17 PM
    #49
    jjw1
    Jesse
    i called him back today...its sold n the guy buyin it is pickin it up wednesday n he wouldnt take anything under $8000 so i changed my mind...how bout this even though its not a wrangler n it has more room!!!
    http://miami.craigslist.org/pbc/cto/1875481252.html
  10. Aug 1, 2010 at 7:22 PM
    #50
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
  11. Aug 1, 2010 at 7:23 PM
    #51
    jjw1
    Jesse
    even though my parents will be towin it behind the rv???
  12. Aug 1, 2010 at 7:30 PM
    #52
    desertdude59
    If they are only using it to run around town and vacation. I read you were talking about a hard core wheel'n vehicle. That liberty wouldnt be my first choice.
  13. Aug 1, 2010 at 9:31 PM
    #53
    jjw1
    Jesse
    idk i like both...even though i know the wranglers will prolly do more but i fell in love with the libertys when they where a concept in 99 or 2000
  14. Aug 1, 2010 at 9:34 PM
    #54
    desertdude59
    The wrangler will take you more places while the liberty is good for some minor wheeln. I've seen one lifted where I live, but couldnt tell how it wheels.
  15. Aug 1, 2010 at 9:40 PM
    #55
    jjw1
    Jesse
    the libertys wheel pretty good but they arent as durable as the wranglers...dont get me wrong they arent pos but after a lot of hardcore shit the libertys will need somethin fixed b4 a wrangler cuz they r unibody
  16. Aug 1, 2010 at 9:42 PM
    #56
    desertdude59
    They also run IFS. The jeep runs a straight axle in the front. I've never had any big problems with my IFS, but a straight axle is the way to go. I'd do some more shopping if I were you. Might find a good one also for about 3 grand compared to 8 and do some MODs to it.
  17. Aug 1, 2010 at 10:35 PM
    #57
    jjw1
    Jesse
    planned on it since its sold!!!
  18. Aug 2, 2010 at 2:35 AM
    #58
    Janster
    Jandy
    Lancaster, PA
    If you plan on building a hardcore offroad rig.... get a WRANGLER.
    In fact, I would search for a used Wrangler Rubicon TJ 97+ years. It'll have solid front & rear axles, Dana 44's front & rear, selectable lockers front & rear, and a better (lower crawl ratio) transfer case. 4.0L engine. Coil spring suspension.
    The only downside to a Rubicon, is they might be beat up.
    Or, look for a YJ (91-94) and build yourself a Rubicon. I had a 92 and 94 that I built. The rig I built is far superiror than the factory Rubicon. Same 4.0L engine with leaf spring suspension.
    Just depends on what your plans on and how much of an offroad rig you're planning on building.
  19. Aug 2, 2010 at 5:49 AM
    #59
    IsmellBacon
    Denver, Colorado
    I have a 1989 YJ with the rabid squirl 2.5L 4 cylinder. It has a 3.5 inch FabTec SUA lift and sits on a 1979 Ford high pinion Dana60, 35 spline inners and outers and in the rear a GM 14bolt. Both are detroit locked and have 5.13 ratios. Earlier this summer I stuffed in a SM465 granny tranny. The 6.55 low gear makes crawling easy with the weak 2.5L while turning 35" BFGs. The 35s are small for for those massive boat anchors, I want 42"+ tires. Any how, in all there is a total of 9-10k in parts including the Jeep itself which I got for 3k. Take your time looking for something you will really like.
    Jeeps will be more expensive because of the Jeep brand name. With a Jeep you will get a narrower machine with a shorter wheelbase. Don't get me wrong I love my Jeep project but I wish I took my time deciding what I wanted for a machine.
    Maybe look at the 3/4 to 1 ton trucks. You will get the heavier drive trains (D60 and larger), longer wheelbase and V8 or even diesel power. It is fairly easy to put larger tires under these trucks. Just do not use lift blocks if you are going to wheel.
    Bacon
