Good exhaust?
Discussion in 'Performance and Tuning' started by travis wommack, Feb 5, 2019.
  1. Feb 5, 2019 at 5:37 AM
    travis wommack
    travis wommack [OP] Member
    travis
    2008 white Tacoma TRD
    leveling kit, tires and rims
    any recommendations on a not extremely loud but deep sounding muffler?
  2. Feb 5, 2019 at 5:48 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I like my flowmaster Delta flow 50 series. I did a video/review on it. No complaints from any neighbors or the boss (wife). The biggest factor for me was that the muffler is designed for trucks with 4/6 cylinder engines. It's easy to "over exhaust" your system by picking a muffler that isn't right for your vehicle.
    https://www.tacomaworld.com/threads...-overland-build.302427/page-200#post-18912955
    https://www.tacomaworld.com/threads...-overland-build.302427/page-200#post-18932763
    This chart should also help you out:
  3. Feb 5, 2019 at 5:50 AM
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    I like my "MBRP Installer Series Single Exhaust System - Turn Down" its cat back just dumps out under the bed of the truck before the rear axl. Its not quiet, its noticeable, but not terribly loud inside the cab, granted that's all relative. I have the 4 banger so its about as deep as I could expect.. The "Drone" level matches the hum from my tires on the highway in terms of volume.
    My sisters boyfriend had a Flowmaster dual setup, unsure of the series, on his V6 and i never liked the sound it made. IMO.. He got rid of it few years later for a Magnaflow setup which was a bit cleaner in IMO
  4. Feb 5, 2019 at 5:52 AM
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    Flowmaster is about the worst muffler company going...
    Your stock exhaust will flow better than a 50 series all day every day..
    Your stock unit has a massive accumulation chamber with baffles.. The Flowmaster designs do not, yet have just as restrictive baffles..
    You'd be better off with a super turbo from Dynomax IMO..
  5. Feb 5, 2019 at 7:28 AM
    travis wommack
    travis
    do y’all know what the flowmaster 60 series sounds like, never heard of it before. curious
  6. Feb 5, 2019 at 7:46 AM
    KeystoneGoodie
    KeystoneGoodie Well-Known Member
    Ben
    '09 AxCab with meat shoes and axe handles
    Lots of dollars and no sense...
    Big fan of my 50 Delta Flow. Not obnoxious but if you know what to listen for you hear it. Most people think it's just stock sound. Has enough throat but doesn't wake up the neighborhood and set off car alarms when you rip past. Also sits nicely up under not as bulky as stock unit. Get it!
    geekhouse23 and Armed in Utah like this.
  7. Feb 5, 2019 at 8:46 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Delta 50 here too......sounds good.......runs good........
    not too loud at all.....
    geekhouse23 and MattCowsmasher like this.
  8. Feb 5, 2019 at 8:48 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Any updates on a prospective bumper:boink:
  9. Feb 5, 2019 at 8:52 AM
    Armed in Utah
    2003 Lexus LX 470
    just got a mssg from Joe there......in stock.....etc....OEM fog lamps work/fit ??
    just about to pull the trigger..........
  10. Feb 5, 2019 at 8:54 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    No they won’t lemme look up the ones I got brb.
    BassAckwards likes this.
  11. Feb 5, 2019 at 8:57 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Magnaflow is nice, I had a super 44 at one point and the drone made me want to drive into on coming traffic on the freeway
  12. Feb 5, 2019 at 8:58 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Here they are, for the price I like them I advise install prior to mounting bumper an I used stock fog wiring for them had to cut off the ends on stock fogs an attached to the piggybacks from Leds.
    Lightronic 2PCS 3.5 Round LED Fog... https://www.amazon.com/dp/B071XND8VJ?ref=ppx_pop_mob_ap_share
    Armed in Utah[QUOTED] likes this.
  13. Feb 5, 2019 at 9:01 AM
    dipstiktaco
    dipstiktaco Well-Known Member
    canada
    2006 TRD off road access cab auto URD supercharged
    I have the urd 3in full system with y pipe and jba long tubes. It is stupid loud and sounds absolutely terrible! I'm going to look into adding resonators to try and tame it
    BassAckwards and MattCowsmasher like this.
  14. Feb 5, 2019 at 1:46 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Who puts aftermarket mufflers on a Tacoma :confused: :crazy: It's not an IROC-Z, stock is as good as it gets.
    Pot_Lickr likes this.
  15. Feb 5, 2019 at 3:14 PM
    dipstiktaco
    canada
    For flow you couldn't be more wrong.
  16. Feb 5, 2019 at 3:16 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    maybe supercharged.... MAYBE.
    but OP stick to stock... aftermarket exhausts on our v6's all sound like shit IMO. really the only v6 that sounds good with an aftermarket exhaust is the VW VR6... and at that point is it really a v6
    KeystoneGoodie likes this.
  17. Feb 5, 2019 at 3:19 PM
    Pot_Lickr
    Ontario, Canada
    Absolutely not..
    Any model of Flowmaster does nothing for your flow...
    Inside your stock exhaust is a massive accumulation chamber... The gases are allowed to fill this chamber for the most part before they pass restriction..
    Flowmaster and other "race" mufflers but baffles right in the direct flow before any accumulation or pressurization...
    If you want to go for more flow it has to be straight through or install a stock F150 exhaust from an 09-10... That is a strait through muffler design with Helmholtz chambers...
    Amazing design...
  18. Feb 5, 2019 at 3:25 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I've got a set of 4" dia Flowmaster Top Ten one chamber race mufflers I just pulled off my Camaro!!
  19. Feb 5, 2019 at 3:39 PM
    dipstiktaco
    canada
    So because they sound like shit the exhaust doesn't work?
  20. Feb 5, 2019 at 3:40 PM
    dipstiktaco
    canada
    Where did I say flowmaster
