Good Jack and Stand Combo
Discussion in 'Wheels & Tires' started by unifyzero, Oct 20, 2012.
  1. Oct 20, 2012 at 4:53 PM
    unifyzero
    unifyzero [OP] New Member
    Justin
    San Diego
    I'm trying to get a gift for a friend. She has an 06 or 07 Access Cab Tacoma. I'm not sure which trim, but she has no aftermarket parts. I'd like to get her a jack and stand combo that would fit comfortably in her truck but still be effective.
    I'm looking at the 4 Ton Heavy Duty Hydraulic Bottle Jack and the 3 Ton Heavy Duty Jack Stands from Harbor Freight.
    Can anyone verify if these fit my criteria or suggest something better?
  2. Oct 22, 2012 at 10:35 AM
    Maximuslion
    Maximuslion Well-Known Member
    depends, is she hot?!?!
  3. Oct 22, 2012 at 1:22 PM
    eric3187
    eric3187 Well-Known Member
    if it is a stock truck, factory jack should be more than effective.. i can lift my truck with the factory bottle jack no problem. my truck has OME lift so you just have to limit the rear end droop if you dont lift by the axle
  4. Oct 22, 2012 at 2:51 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Costco arcan $100 jack and hf jackstands.
