Good Load range for tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TSmalls89, Apr 5, 2013.
  1. Apr 5, 2013 at 11:45 AM
    TSmalls89
    TSmalls89 [OP] Technologically Advanced Redneck
    Tyler
    Merrimack NH
    2022 Tacoma TRD Offroad
  2. Apr 5, 2013 at 11:47 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    alot of people say E is overkill for some reason, but me and my buddy with a taco both run E, mine in 245s
  3. Apr 5, 2013 at 11:50 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    E IS overkill for a truck that can't haul more than what a P-rated truck tire is rated for... To put it in perspective, E rated tires are what you'd typically see on a 1-ton truck. In my opinion, the only reason to have that high of a load range on a Tacoma is for the stiffer sidewall for off roading. Otherwise, you're just pissing away MPGs.
  4. Apr 5, 2013 at 11:56 AM
    TSmalls89
    Tyler
    Merrimack NH
  5. Apr 5, 2013 at 12:00 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Why?
  6. Apr 5, 2013 at 12:29 PM
    TSmalls89
    Tyler
    Merrimack NH
    I've always had good run with Coopers, had Goodyears and wasn't a fan. Never ran BFG, and this is my first run with these Dunlops.....
  7. Apr 5, 2013 at 12:49 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
  8. Apr 5, 2013 at 12:56 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Wouldn't MPG's be about the same if not a little bit better since they're stiffer? Or is it the weight? I have E's as of right now and I also believe they are overkill. I think D's would probably be perfect. If you ever need to air down E's are pretty unhelpful...
  9. Apr 5, 2013 at 1:00 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I tested a set of Goodyear MTR load range E on hwy at 75 mph and got 20.7 on a 200 mile trip. Mix of 2 & 4 lane. MPGs dropped off a little with the same size Duramax load range C. I am not convinced that Es will necessarily drop MPGs.
  10. Apr 5, 2013 at 1:02 PM
    JDMcQ
    The load range has little to do with fuel economy. The issue arises with increased weight usually associated with E-rated tires.
    Even off road, E-rated tires are unnecessary on a relatively light truck.
  11. Apr 5, 2013 at 1:11 PM
    JDMcQ
    Huh?
  12. Apr 5, 2013 at 1:21 PM
    Redfox1
    Conner
    The difference between D and E load rating (for BFG's AT) at 285/70/17 tire size is 3 lbs per tire. Seems negligible?
  13. Apr 5, 2013 at 1:27 PM
    JDMcQ
    Every pound of unsprung weight roughly equates to 10 pounds of sprung weight. Also, the heavier the tire, the harder your engine has to work to get it spinning. 3 additional pounds makes a fair amount of difference.
  14. Apr 5, 2013 at 1:43 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    Some guys have reported getting 50k miles out of E rated Toyota MT's due the trucks lower weight. I've got 15k on my set and they still look brand new. These tires wear like iron on a small truck.
  15. Apr 5, 2013 at 1:51 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Load Range C
    D & E give harsh rides
    Maadanchik likes this.
  16. Apr 5, 2013 at 2:00 PM
    stump jumper
    Bill
    Texas
    for what it is worth my Duratracs are Cs. They are available in C, D, & E. I take these tires through rocks, cactus, and stumps. You are correct on the Duratrac plys. I even wrote zn email to Goodyear but got a run around answer explaining tire construction and why they developed the Duratrac. Bottom line on the Tacoma is why spend the extra money.
  17. Apr 5, 2013 at 2:14 PM
    TSmalls89
    Tyler
    Merrimack NH
    Alright, so so far if I do go with the 285/75/16s I should suspect a stiffer ride than if I stick with the stock size. Awesome, gonna look more towards the 285s because of the level kit, hopefully I can get a good set-up PLUS some nice aftermarket off-road rims.
  18. Apr 5, 2013 at 2:50 PM
    JDMcQ
    Now about that leveling kit...
  19. Apr 5, 2013 at 3:33 PM
    Pugga
    Massachusetts
    Yes, it's the weight of the tires. Highway MPG isn't overly affected but around town you'll notice heavier tires.
    So you're saying that the weight of the tire is why load range affects fuel economy :rolleyes:
  20. Apr 5, 2013 at 3:42 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    I have E and can’t tell a difference from the stupid POS P rated rugged fails. I think they handle even better then the rugged fails did. I was going to get D rang but discount was out and was all out, and i needed tires really bad.
    I only lost about 1mpg. if that really.
