goodies on the way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j1999t, Aug 20, 2009.
  1. Aug 20, 2009 at 12:44 PM
    j1999t
    j1999t [OP] Well-Known Member
    Justin
    Northern Colorado
    traded it in
    just ordered front and rear 5100's for my 06 tacoma from downsouthmotorsports.com
    how long did it take you guys to get them? i dont have the tsb for the rear leafs, so what should i set the fronts to?
    thanks!
  2. Aug 20, 2009 at 12:47 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    hey since you have 4x4 i recommend getting a half or quarter inch top plate spacer (from toytec) for your drivers side to prevent taco lean... trust me do it now before you get everything on and alligned you will be happy you did! :)
  3. Aug 20, 2009 at 12:49 PM
    j1999t
    Justin
    Northern Colorado
    traded it in
    how much is the spacer going to cost
  4. Aug 20, 2009 at 12:53 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
  5. Aug 20, 2009 at 12:56 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    1.75 with no aal in the rear
  6. Aug 20, 2009 at 6:02 PM
    j1999t
    Justin
    Northern Colorado
    traded it in
    will the 1.75 ride rough? i was going to set them at 0.85, but im not sure what to do
  7. Aug 20, 2009 at 9:58 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    i just had mine installed at 2.5 and they dont ride rough so I wouldnt worry
  8. Aug 20, 2009 at 10:06 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    Are you just trying to level your truck? Measure it first from ground to fender, both at the front and rear. The back is usually higher. Get the difference and from there you decide how much lift you want in front.
    I have mine set at 1.75" and it gave me exactly 1.75" of lift. I have TSB spring in the back, so it's levelled. TSB spring lifted the back by 1.25" (others typically 1.5") but then settled to 1" later. Since you don't have TSB spring, 0.85" might be just the right.
